I tow a 2015 T@B 320 with a 2013 Nissan Xterra. I find that my low beam headlights are always annoying oncoming traffic. I was considering installing rear air bags, but they are quite expensive (700 to $1700, installed). Instead I think I will go to a weight distributing hitch, which is less than $300. Any experience with leveling out headlight beams? Any other words of advice? Thanks.
0 ·
Sold 2023 Tab 400
Sold 2018 T@B 320S
Edit to add: Also, stiffer rear springs may be less expensive than rear airbag systems. Some vendors make ones that still provide a decent street ride when not towing. I’m looking at adding Subaru specific Rallitek springs to my Outback if I decide to stick with trailer camping much longer, though mostly I avoid the headlight issue by keeping my load lighter. But similar springs that aren’t too heavy duty and stiff for daily driving might be available for the Xterra.
https://www.amazon.ca/gp/product/B098C7JVXW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
As for weight distribution hitch, Nucamp doesn't recommend them on the frame they use (C channel frames) for their trailers. That being said, a number of people have installed them successfully.
A WDH isn’t a bad thing, but they design them for much heavier trailers and heavier duty tow vehicles than the very lightweight 320. Simply put, if you *need* a WDH with a 320, you’re almost certainly carrying too much for your vehicle/trailer combo. Properly loaded, at most you should need a bit of rear end support (because lightweight tow vehicles are generally built for passengers and freeway comfort rather than a 300 lb tongue weight + fully loaded cargo area). And maybe a friction sway bar, though typically correct load fixes 95% of sway issues.
A friend and I have the same tow vehicle (very soft rear springs) and 320s (different years). On a recent trip together, her tongue weight was 100 pounds more than mine, and her cargo area behind the axle was much more heavily loaded. Her car visibly squatted, whereas mine barely budged. Loading, both overall cargo weight and position of that cargo, makes ALL the difference.
Additionally, though, your first step in evaluating both that question and your original problem is the same: What is your loaded tongue weight and loaded trailer weight? This is critical information that you should know before every trip. Getting rid of the tire may make it difficult to keep the tongue weight in the ideal range for safe towing; it should be between 10-15% of the overall loaded trailer weight.
