Hi all - relatively new Tab 320 owner here… twice now we have gone to disconnect at a campsite and found one of the 30amp fuses blown, rendering battery useless.
Is this just general wear and tear after a year of use, or something else?
We tow with battery in “on” position and fridge running. Any correlation? Is that the wrong thing to do?
Any help much appreciated!
1. Turn off Alde and CoolCat, and any other 120VAC appliances you are running.
3. Turn off 12VDC Battery disconnect switch (optional by a good idea)
4. This is the big one, make sure you turn off the circuit breakers in the shore power pedestal, Before connecting the shore power cable to the pedestal. Connect the cord to the TaB first and then to the pedestal with its power shut off.
Do the opposite when disconnecting, and Bob’s your uncle...
If the battery is way low from running the fridge on 12vdc while towing, the charge line from the tow vehicle may not be keeping up with fridge amp draw. Maybe when you connect to shore power the battery will take all of 30 amps or 35 depending on output from converter, blowing the fuse.
My 30A fuse holder at battery needs to be replaced due to this overheating. I went through 3 30A fuses before the fuse held and the battery kept charging. Just my experience once. YMMV
What is your towing vehicle?
Something is wrong.
In general there are three 30 Amp (or above fuses) in the trailer:
1) an in-line fuse on the battery positive terminal
2) a 'Battery' 30 Amp fuse at the Power Center DC Fuse Panel
3) a 40 Amp fuse for reverse polarity protection also at Power Center DC Fuse Panel
Which Fuse(s) are Failing? And when do they Fail ?
Something more than new user "oh darn" sequence of events is causing the fuse(s) to blow.
I’m thinking we need to investigate something wrong with the tow vehicle hookup. Any recommendations on that?
Some other questions: Did it ever work correctly, or has it always blown the fuse every time? Does it blow immediately when plugged in, or does it only happen after towing for a time? What brake controller are you using (hard wired, or wireless) to control the brakes while towing? Have you tried it with another vehicle? (Perhaps a friend or a nearby Tab owner could assist.)
In general, when asking for help, it’s also useful for us to know the year and model/trim level of both vehicle and trailer, as different model years can have very different configurations. For your specific issue, knowing the battery type on the trailer may also be helpful, as traditional lead acid charges at different rates than an AGM or lithium…and that may be coming into play when the battery tries to pull from the alternator or vice versa.
