I recently inherited a 2006 Dutchman T@B with the ALKO chassis and discovered it was leaking from the
clamshell hinge area and there's spots of significant water-damage from under the kitchen to about 3/4 of the way to the axle.  There's one spot under the passenger side bench storage area where the chassis bolt is clearly rusted and there's a distinct rise in the floor where the T@B sits on the frame.
I spent a couple hours researching on this and other forums and facebook groups and reached out to NuCamp about floor replacement options only to learn they aren't selling floors anymore and no longer seem to have any interest in working on the Dutchmans.
Has anyone done a floor replacement without a factory floor?  I've seen several accounts of people having the body detach from the chassis on the highway. It would be a challenge to build something light enough but with sufficient structural integrity for the unibody-like design.
The ALKO chassis is so hard to get parts for, I'm honestly wondering if it would make more sense to just have a good fabricator build a new chassis the camper body could be moved to so it could be re-built with a much higher GVWR.  The ALKO's axle has some rust on the torsion arms, anyway and it's impossible to get a new axle in the the US. Even the brakes and bearings are hard to find.  It probably wouldn't cost more than the $5000 NuCamp was reportedly charging for the new floor and it could give the camper another 10+ years of use.
To do this, you need to strip out the TaB’s interior built in furniture, bunks, galley, etc.
Next you need to unbolt and unscrew the fasteners holding the body to the frame. There are going to be rusty fasteners that will be difficult to remove.
Then you need to Jack up he body off the frame. Now you can get down to designing and building a new frame to take a Dexter axle being used on current TaBs.
Those projects are great when you have an emotional attachment to the vehicle you are restoring. When you finish, the end product is always rewarding. Just like a modified car, you will have considerably more money into it than it will be worth. But, the monetary value isn't the point of the project. It's the project itself.
"Just Enough"
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL
Will nüCamp sell you a 320 frame and axle? Are the wheels and axle located on the same place on the frame? More info is going to be needed. When I upgraded my TaB axle to a Boondock axle, Dexter axle and wheels cost around $900 from nüCamp.
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
MOUSE-KE-T@B
Harvest, AL
Project was successfully completed! I've held off on making a complete post until I had some time to make sure the rebuild hadn't created any problems but so far so good.
I did it over a 6 week period but not working constantly. It was definitely a good chunk of hours, though.
You are now a master T@B rebuilder.
T@BMahal
'04 #100
What's next? ; )
"Just Enough"
Wow! Mine is actually a 2008 and was made by Dutchman in the US but built on the Euro Alko chassis. I have a set of early drawings ('06 maybe?), which may have been the first USA model. I'm not crazy about all the stuff they crammed in the new ones but they've definitely beefed up the frame and chassis--weight is almost double.
Wow, mine wouldn't hit 1200lbs even if you pulled the AC, fridge, batteries, water tank and spare tire.
As such, I thought I'd update with some other improvements I've made that could be done in conjunction with the rebuild. Why not build it back better, right?
I've now got lots solar/electrical upgrades, a new roof fan, a shower/sprayer hookup and new window shades. All I have left to do is replace the Cool Kat, and maybe one day get a welder to adapt a new Dexter axle to the chassis, and I'll basically have no potentially-problematic components remaining.
If you decide to do a floor swap, feel free to DM me and I can share some resources that helped me. I am by no means a professional so certainly do you're own research and consult a professional to make sure you're doing things safely!
