See message I sent to tech support. Any thoughts from the forum?
We are on an extended road trip without water hookups so relying on fresh water tank and pump. Had a problem with the drain valve (yellow flapper valve) releasing every time the pump shut off. Replaced the drain valve and that seems to.have resolved that issue. I do notice, however, that we have water dripping from that drain tube under the trailer when using the pump. Is that normal? We will be on the road a couple of months so need peace of mind. Thanks- Dennis
2015 320 Max Q
North Carolina
2015 T@b Max Q
North Carolina
2015 T@b Max Q
North Carolina
2015 T@b Max Q
North Carolina
2015 T@b Max Q
