We will be heading to Maine in September and the possibility of below freezing temps at night exists. Any thoughts or experience with this type of tool for a quick remote blowout of the lines:
https://www.amazon.com/gp/product/B07ZTGF5BG/ref=sw_img_1?smid=A3H8B8K05X191&psc=1Advice on other/better options are also appreciated.
This unit permits you to set the psi and can work on either a 20v rechargeable battery or from a 12v outlet.
I also question as to the effectiveness of running the Alde along with heaters which have been installed on the tanks as an option.
Thanks for any advice.
The Alde absolutely keeps the inside plumbing from freezing. If you have tank heaters that are intact they should be fine. Remember, a full tank of water takes a long time to freeze. This has been discussed here:
https://tab-rv.vanillacommunity.com/discussion/comment/156894#Comment_156894
https://tab-rv.vanillacommunity.com/discussion/comment/106557#Comment_106557
https://www.amazon.com/Vibrant-Yard-Co-LLC-Inflation/dp/B09HYLX3R2/ref=pd_lpo_2?pd_rd_i=B09HYLX3R2&psc=1
@Gherzig, I've used a small portable compressor when on the road in changing temps. But if it were me, I'd avoid that no-name compressor, and get one that will last more than one season.
Per @jkjenn's advice, I bought a Viair. They make very nice (albeit expensive) portable compressors.
Oneonta, NY
No check-valve, thus:
Now, in the spirit of full disclosure, I must confess I’ve never winterized our camper. We keep it in a heated garage.
