We switched to a 12V chest refrigerator on a slide that has battery protection. The problem is that it relies on a voltage reading taken at the fridge. When the fridge is running there is a significant drop in the reading that does not reflect the actual voltage of the battery. It's been brought up here many time that you can't determine a batteries state of charge when under load or charging. The 54qt chest fridge that replaced the original works fine because the protection level is adjustable, but we purchased a 21qt for additional space that is permanently set to fault out at 11.3V. It's been a challenge to keep it running.
This post is mainly to vent and let you know that if you get one of these 12V chest refrigerators, be sure the battery protection is adjustable.
Ontario, Canada
2018 Tab 400
Ford F150 2.7 Lariat
South Jersey
