Running an air conditioner from an inverter is not
practical, because of battery life. Also, there's no way to power the
Air8 from a little generator like the Baja 700/900W. What about plugging the Air8 into a large enough inverter
connected to the batteries, then
plug the T@B's shore power cord into the little generator. Would the inverter
handle the AC startup and running requirements while the generator did its
best to maintain a decent level of charge.
There's probably something seriously
wrong with this, but someone once said that there are no dumb
questions. We very, very rarely use our AC and have no plans to take this approach. I'm mostly just curious if or how well it would work?
I put this question out there at the end of another thread, but it
either got lost there or is not worthy of discussion. Trying one more
time here on its own before letting it go.
If OK using a propane/gasoline/diesel generator for part of the power (if even possible) why not just purchase a higher output propane/gasoline/diesel generator in the first place. The single correctly sized generator will also have a far lower initial purchase cost.
Curious why the change for the AC ? The older T@b 320s have a simple 500W window air conditioning unit which runs just fine off a small 800W inverter generator (at least for me).
Just took a look at our Progressive Industries EMS readout with the AC turned on. The Air8 draws 7 amps with the fan and compressor running.
Baja would be powering the WFCO Power Center Convertor.
Baja would be outputting a steady ~ 600W. It would not increase output during the Air8 compressor start-up {32 A @ 115VAC} as the WFCO is limited to a maximum output of 475W.
A 2000W continuous, 4000W peak Invertor might/should handle the compressor startup demand of 3680 W. Then while the Air8 is running compressor+fan at ~10.5A it needs ~1210 W. For the Invertor to output 1210W its 12VDC input side will have to be ~1344 W. 1344 W minus 475W (best case) from WFCO means the Battery must supply ~ 870 W. That is around 65 Ahr . . . . a huge hourly demand.
There are several in the 50# range that cost under $400.
My i2000 (1800 W continuous) is carried on the TaB boondock platform.
Can run the Window A/C and WFCO at the same time.
Many inverters on the market have efficiency rating in the 80-85% range; making our little back of the napkin mind game nearer ideal for available power.
The WFCO also has an efficiency of about 80% as it needs 600W to generate 475W.
Having one or two solar panels will help under ideal conditions but cannot be counted on.
Say you have one 100W Ideal Rated panel, it's ideal output will be 4.7-5.3 Amps depending on the brand. The panel will never operate under the ideal conditions to set its marketing Wattage output. Even in direct sunlight lets pick an output level of 3 Amps ( 3 Ahr) . . . your best case battery drain is still in the 28 Ahr range.
No matter how fancy the battery/inverter/solar panels & controller within a very short
time period the battery bank will be dead (at an unsafe level to continue using). Now how
many hours of prefect sunlight will be needed to recharge that battery bank?
Anyone that needs/wants A/C while boondocking should just bite the bullet
and purchase a correctly sized generator . . . and in this threads mixed power
source situation there is already a noise source generator running . . . a slightly
larger one won't be noticeably louder.
On our 2021 320 the Air8 had a 120v outlet in the Alde compartment, however the Air8 interface is wired from 12v circuit #2 from the (former Wefco) converter.
Our little Ryobi 1200w max genset runs the Air8 (via trailer input) just fine the few times we've needed it to.
See prior thread:
https://tab-rv.vanillacommunity.com/discussion/15060/air8-and-microair-easystart-read-this-first-so-that-you-can-avoid-our-drama
Elwell Air8 data:
6000BTU 2.3SEER
900W
starting current 15A operating current 9A. With the soft start the starting current draw is less.
weight is unstated. There is no technical data on Elwell website.
Veering off topic...
The Air8 cools quickly and well and can be set to cycle within setpoints. We have several issues with it.
1. Compressor does not kick in on initial fan start, you have to wait up to a few minutes- very inconsistent. The Soft Start data refers to "training" it with 5-7 starts however this behavior remains since inception.
2. On our highly defect ridden Jan.2021 TAB 320, the Air8 thermostat thinks the cabin is 12-15 deg F cooler than actual, and the separate Alde thermostat thinks the cabin is 15-18F warmer. Grrrr. A lot of time spent on forensics and calls without resolution. Thermostat programming 'offsets' do not begin to correct the setpoint error. I've seen 2020 posts here about relocating the thermosensors.
3. The compressor and fan are incredibly noisy.
Having installed several minisplits, I am starting to look options to replace the Air8. Ironically many residential heat pumps actually run at about 19v DC internally (as I understand it) so there's a lot of inefficiency Inverting 12V battery rack to 120V for the unit connection, and then internally back down to 19 or so. There are 24v and 12v trucker units so starting research.
