We are looking at a used 2022 boondock and I was wondering if soot buildup around the exhaust vent is typical (see photo) or an indication of too lean a mixture in the burner. My concern is that the heat exchanger could require cleaning and additional expense. Thanks
I’d tend to think from the responses so far and from a couple years of watching this forum that it’s not a common problem, though obviously not an unknown one. And because it’s not common AND you’re looking at a unit so new that it can’t have had a ton of use, I’d be leery of buying that particular rig unless it was serviced prior to purchase by a well qualified Alde tech. Something’s not right.
2020 Tacoma TRD Off-Road
However, expect the soot was because the Alde was not in High(er) Altitude combustion fan mode.
Because if the Alde "seems to be running OK - - no weird freight train noises" I don't change modes . . . . the manual says to change modes when at/above 3,000 feet elevation which I don't follow - - - - after all I grew-up in a town that was at 7,500 feet so my mine set is High Altitude is > 10,000 feet - - - perhaps I should review the combustion physics instead of my youth experience
