I own a 2015 Outback. The fan was running while camping and sitting under it and then it just stopped. I replaced fuses in the unit and down below with no success. I pulled the unit out (see picture) and used my ohm meter to see if I could figure it out. The two clips/wires to the fuse gave me a reading. The fuse clip/wire on the right that leads to the switch clip/wire, also on the right, gave me a reading. The switch clip/wire to the bottom rigid wire with the tube in the middle (looks like a diode), gave me a reading. When I checked the wire on either side of the tube, NO reading. The fan switch was on #2 when I was doing all this. QUESTION: is this my problem or am I missing something in the process or this wouldn’t show up on an ohm reading…?
'Fuse' implies it can fail; 'Link' implies it could reset once cool.
FFan describes the Speed Control as:
" 3 Speed and Off-Resistor Switch w/ Thermal Link "
With all power off to the fan [remove the fuse to be sure] an ohm-meter will read zero or near zero ohms if the fuse/link is Okay . . . or very high resistance if open or tripped.
Do Not Forget the Thermal Fuse/Link could have failed for a reason - - - such as a fan motor problem.
You can also short the Thermal Fuse/Link with a piece of wire to help isolate the failure point.
You have attempted to operate the FFan at power 3, correct? As that power level won't require the wire resistors to be good.
I have attached an Edited Version of your picture file,
the edit includes a reference posting from another forum for this problem.
Adventures: 55 Nights: 376 Towing Miles 46,920
MuttonChops, thank you for taking the time to explain the FFan. A couple of follow-up questions. Are you saying in the revised photo that I can bypass the thermal link by hooking up the wires after the thermal link? If so, could you describe which and where the wire(s) would be connected. Also, I like you switch idea that provides a 0-100%. Can you provide me some detail on what you bought and where? I think I might want to go in that direction. Michael
Best method is to use double-ended-aligator-clip-jumper-wire.
Place one clip on each bare wire end of the Thermal Link:
For that project I used a made-in-china, amazon purchased PWM board:
https://www.amazon.com/uniquegoods-DC-Controller-Adjustable-CCMHCW/dp/B00QA6E4QO/ref=sr_1_3?crid=36EX0X9UD4MLN&keywords=uniquegoods+12V+24V+36V+10A+PWM+DC+Motor+Speed&qid=1662238989&s=industrial&sprefix=uniquegoods+12v+24v+36v+10a+pwm+dc+motor+speed%2Cindustrial%2C328&sr=1-3
Of course it is no longer $10 bucks.
https://tab-rv.vanillacommunity.com/discussion/8556/fantastic-fan-upgrade-to-7350-dramatic-improvement-in-efficiency#latest
(page 8)
So I also have the spare parts left over from the 3 speed wire resistor switch that I can send.
Juliet and Andy in Massachusetts
