I'm in the middle of an attempt to install an inverter in my 2020 320S. Dropped one side of the splash guard under the trailer to run the wires and found this. They look like inserts for bolting something somewhere. From the view I have I can't see where they could have come from. If someone could identify them and have an idea how they got under there it may save me the unwanted work of tearing things apart in hope of finding the answer. Getting too old to be crawling under this thing.
Attached is a photo of the structural rivets holding the trailer frame together. Look forward of the step. Elec cable is my work.
Red marker is NuCamp inspection in factory, as these are critical.
Please immediately look at the frame exterior on both sides too see if you have missing rivets. Somewhere I saw an old post from someone who had to rebolt these connections.
Crawling under with a bad back as well. Putting a mic on these I get 0.48 inch diameter at the widest ring sitting against the trailer steel. Roughly 0.34 at the small end of cone and very roughly 0.24 Dia bolt insert. These measurements should suffice for you to measure whether your loose hardware matches this function. They sure look like it!
Good luck. Call NuCamp to discuss.
Has your repair has held up well? Any shifting since replacing?
Did you contact nuCamp and if so, what was their response?
Without more information, it would be difficult to determine the root cause of the failure. Yes, it could even be that the fastener used is not large enough to create sufficient clamp load. It could be operator issues, tooling issues, or even caused by overloading of the frame - IE the design engineer made an error in the calculation of the actual load.
Brad
Concord, NC
2020 TAB 320 S Boondock Lite
2019 Toyota 4 Runner
Puget Sound Country
P.S. Make sure to use hardened steel washers between the head and nut surfaces to contact the frame.
Brad
Concord, NC
St Catharines, ON
