jkjenn
Member Posts: 6,417
NOT SO FAST:
I don't have a grey water tank, just a drain tube at the bottom of a catch pan underneath the A/C (located at floor level). During two years' of use I have never seen one drop of condensation from the tube or in the pan.
I mentioned this to one of the guys at Tearstock last year. He said that it was not unusual for that to happen. He was busy and I didn't press for an explanation, but I haven't been too concerned about it.
Happy Trails Y'all
Happy Trails Y'all
Condo A-Go-Go
2017 Tacoma (AH GOGO)
S. UTAH
Hot and humid today. I was out getting the T@B ready to travel, so hooked up the a/c to make sure it was operating. After running for quite some time, absolutely no condensation, including none in the pan or on the unit that I could see. I really think it just evaporates. One reason being that I noticed it would run just a little while, then the compressor would kick off while the fan kept running. I don't think the compressor runs long enough to generate enough condensation to drip. I checked the controls to see if there was a setting that would make the compressor stay on longer and found none. This could be another reason that the unit does not cool down the trailer as much or as fast as some would like. Perhaps an auxiliary fan inside the cabinet, as others have mentioned, might make the compressor run longer as I assume the compressor kicks off after reaching a certain temperature.
My unit is a Friedrich mounted in a cabinet on the floor. Your mileage may vary. Seriously, your model, where and how it is installed will affect how it operates, so if someone says an operating condition or problem solution works for them, you should not assume it will for you as well unless you have the identical unit and installation.
Happy Trails Y'all
2016 T@B Q ~
2015 Jeep Cherokee Trailhawk
If there was that much condensation from the a/c, seems it should have drained or dripped some while parked. I would check the drain tube (located in the center of the drain pan) and make sure it isn't stopped up. You can do this by running a pencil up through it. I have heard of some being clogged by trash or insects. You can also check to see if condensation is collecting in the drain pan by shining a flashlight in through the grate from the outside. I've done this before.
Happy Trails Y'all
This is a good point - 2x when not level. I have leaked, so it is collecting it. Back to the question - does it really go to the gray tank? Inquiring minds want to know!
On a similar note, for those wondering where the water in the pan "normally" goes when it is not dripping onto the bed (one's own fault), as i righted the T@B to level, water from the pan beneath the AC unit GUSHED down and out of a drain tube, driver's side behind axle. Important lesson learned. Level AGAIN after deploying the stabilizers.
Now, if can just figure out why the norcold won't stay lit on propane. It has a full LP i was told by my dealer, so that should't be the issue. The good news is that after about twelve hours on shore power mode, it is cooling and keeping my beer and yogurt cold. Since mine is a 2016, it came with the fan installed and as others have notes, the countertop does get warm to the touch but not enough to melt anything.
PS. I love my new T@B and the reason i woke up at 5am waa because i was cold. The inside temp was 70, outside was about 90. I did have to rig a wind deflector in the early evening hours, to get the air to point down onto the bed as it felt as though it was just shooting cold air to the top of the cabin.. I used one of the 8x11 warranty cards, bent it lengthwise, and slid it in the slot between the top of the unit and the housing wood. I will look for a better plastic deflector mod thingy, but the cardboard is working for now to route the air downward. Or, mabe i will get a small fan as other have done. Thanks again to all who came before me for tips and tricks.
Be brave. Take risks. Nothing can substitute experience.-Paulo Coelho
JENN. Will do, not urgent at the moment as i have NO need for hot water and do have shore power, but it is on the list for once i get home.
I am in heaven with regard to the amount of living space and the benefits that come with being able to stand up, pee if need be, change clothes, watch a movie, grab a cold beverage, brew coffee, make a sandwich. It is all at arms reach. While i dearly loved my silver shadow, the T@B just makes more sense for me, all the way around. I got the stock Sofitel mostly for the slick dog-friendly (hair doesn't stick to them) cushions, but I am finding I really like the gray walls and boat deck flooring too. There are also so ways to hang and store things from the valances. Super happy.
I found my drain tube was wedged into the I-beam that is next to the tubing. As soon as the drain tube was moved, it started dripping.
We were having over 90* temps with 60% to 80%+ humidity at Tearstock. I love my A/C
One night, Sunny Day took my spot on the bed while I used the bathroom and I had to partly sleep under the cabinets. I figured I could tolerate it and if she found it cooler in that spot, then I wouldn't have a sick dog from the extreme heat. Yes, maybe a deflector would direct the air more in the middle of the bed, rather than just at the head of the bed (or door side of the T@B).
Happy Trails Y'all
