When I drain the fresh water tank using the drain valve, will this also drain the pump? I do not want to have to go through re-priming the pump from taking it dry.
Ultimate Toys Teardrop Camper Volvo XC-40 SF Bay Area, California
In my experience draining the tank will require re-priming the pump. There is no "process" per se--the pump should be self priming--but the process will introduce air into the lines that will need to work itself out when you open the taps.
2015 T@B Max S (320) 2015 Nissan Frontier SV V6 4x4
I've never had to prime the pump on my 2022 after draining the water tank. I empty the fresh water tank and open the hot and cold water low point drains after each trip.
Volvo XC-40
