Major water leak from under Alde
We dewinterized our camper this spring, sanitized the tank, filled up with fresh water and headed out. At the campsite we discovered we had a water leak. After turning on the pump there was water on the floor inside the trailer running out from under the bench were the Alde and water lines are. It was also running out underneath the trailer. We lost most of our water and camped without using any running water.
We finally got around to doing some trouble shooting this weekend. We double checked that all the valves were camping season mode and turned on the water pump. Water started running out from the drip pan under the front corner of the Alde. We then bypassed the Alde closing the hot and cold-water valves and everything thing was fine. Water running in the kitchen but nothing leaking inside the trailer or outside from underneath. We’re going to make some phone calls tomorrow but I’m wondering if anyone has an idea of what the problem is. We have a 2020 Tab 320 S.
The picture shows exactly where the water’s coming from.
2013 Nissan Frontier
2020 T@B 320 S Boondock Edge: Sm@lls
