This morning I noticed a dripping from under my TAB400 where the bolts that hold the rear stabilizer jacks are attached. I opened up the panels under the bed and found water around the base of the Alde 3020. Not glycol, just water. No obvious leaks at the connections, just from the base. Yet another headache with our TAB. Any suggestions? I have to wait til Monday to contact NuCAmp. Thanks, Mark
2021 T@B400 Boondock
2008 Toyota Tacoma
Silver Spring, Maryland
0 ·
2008 Toyota Tacoma
2008 Toyota Tacoma
@madtrout Edited for photo size. Please learn to reduce your photo size. Moderator
2008 Toyota Tacoma
Virginia
2021 T@b 400 BD (N@lu 'Ima Ola)
2013 Toyota Tundra Ext. Cab V8 5.67L 4x4
Virginia
Here are three relevant discussion threads:
https://tab-rv.vanillacommunity.com/discussion/7304/alde-drip-pan
https://tab-rv.vanillacommunity.com/discussion/13033/bad-alde-internal-water-leak#latest
https://tab-rv.vanillacommunity.com/discussion/13425/leaking-around-base-of-alde-3020#latest
