I'm curious if it makes any difference if I were to replace my AGM battery in my 2021 Tab 320s BD with 2 Lithium batteries rated at 100-105 Ah's or 1 lithium battery rated at 206ah's. I am looking at a couple different brands. 1st is Lion Energy, Lion Safari 1300, Battleborn 100ah 12v, SOK 206ah 12v/ lifepo4 There is a price difference here, the SOK is not made in the USA & is several hundred dollars cheaper. All have similiar specs with the exception of the ah's. Any and all advise is welcomed, if you have a good reason for your sugestions, please explain. Thanks
4 x 100 Ah for me, I agree that Battleborn has a premium product and made in the USA.
Brad
Concord, NC
Another question, I have the stock 105 watt solar panel on the roof of the 320 Tab. I was hoping to stay with only this one, & maybe upgrade to a suitcase solar panel if needed in the future. I realize this will take longer to charge with 2 100ah batteries & I am going to upgrade the converter to a lithium converter. Do I need to do anything with the solar charger Victron MPPT 75-15? Or will it still work until I add more solar?
Thanks
TV - 2008 Toyota FJ Cruiser
Retired aircraft mechanic from AA
2-3 several week trips per year & other trips we can squeeze inbetween our long trips.
Avid road bicycle rider. always carry a bike or 2 with us.
The only "modification" if you will, is the installation of the Progressive Dynamics converter under the bed. Otherwise, everything is wired exactly as NuCamp set it up and the Battleborn batteries are in parallel as per their recommendations.
Battleborn recommends additional equipment if you are going to charge above 4000 watts. Using 15 amps from the solar and 60 amps from the PD9160ALV, my maximum wattage is less than 1100 watts at 14.6 volts.
Here is the excerpt from their manual in regard to devices over 4000 watts.
Brad
Concord, NC
https://www.sokbattery.com/products/sok-12v-206ah-lifepo4-battery
