We have a 2022 Tab400 and we have recently seen a significant voltage drop when putting some load on the standard agm battery.
Dry camping and using lights, fans, (fridge on propane) and after a short shower running pump, we saw a sub 11V reading on an almost fully charged battery. See smart shunt image. Note that the solar is charging so the load might be around 100W.
We have never had the battery below 60% and we generally see good battery life.
Any thoughts on this? It drop seems excessive and it also causes an Alde failure message.
Just as a note, when removing the load the voltage went back to expected levels.
Either the state of charge estimate is way off, or the battery is already shot which would be unusual with such a new trailer. The best way to test it is to charge it off shore power for 24hr when you get home and then retest with the same load. See how long it takes until the voltage drops that low again.
What kind of battery(s) do you have. I assume AGM or Lithium. Lithium is much less prone to sagging under load. I assume that you are using some kind of heavy load on the inverter to be using 100 amps.
I'm already back home and this issue was a couple of days ago - unfortunately I didn't do a screen shot of the solar at the time. I estimate that it was pulling in about 80W from solar and that's why I'm guess that I was pulling around 100W total (Note: not 100 amps). It's two 6V AGM batteries - I'll do a closer inspection tomorrow.
I'm not sure how the app calculates the percentage, because I would think it should be lower according to the Volt reading. But after most of the load was removed, it came back up to a Volt level corresponding with the 91%.
managed by VE Smart Network
The other issue that can impact the accuracy of the BMV is the use of multiple charging sources. Apparently, going from TV, to Solar to shore power can alter how the BMV reads. From time to time, I charge using a separate battery charger and resync the BMV to avoid aberrant readings.
The SOC is synched to 100% on the BMV-712 based on the following settings.
Charged voltage
Tail current
Charged detection time
If these are at the "default" which are auto configured based on detected battery voltage, they are all incorrect.
When I was using the Harris AGM, my settings were as follows and it worked well.
Charged voltage - 14.2
Tail current - .5%
Charged detection time - 5 minutes
SOC is reset to 100% when the voltage is over 14.2 with less than 1.12 Amps for a minimum of 5 minutes.
What I believe may be happening is that your SOC is resetting to 100% when they are not fully charged. I had this exact issue early on and discovered that it was due to not properly configuring the BMV-712 when I installed it. I would venture to say that even if someone installed it for you that it may not be set up properly.
Brad
Concord, NC
We are definitely moving a lot between power sources so that might be it. The “almost fully charged” was based on a SOC reading. On the first screen shot it doesn’t really seem to match the voltage but after removing the load, the voltage went back up to around 12.5.
if the battery is actually on its way out - what’s the best way of testing that? Trailer is under warranty but I’m guessing dealerships are not the best way?
Now, the batteries may be on their way out also, that would require some load testing, or the common test today uses an internal resistance measuring device.
I would also suggest changing your Charge efficiency factor to 80%, as this is what Harris Battery told me when I inquired.
Brad
Concord, NC
On another note, my new updated battery settings for the smart shunt, it seems like Victron never get's to synchronize and it just hangs at 95-96%. Should I try and tweak the tail current - or synchronize manually?
Thanks again for all your input!
While as a Production Hardware Engineer I spent a career trying to resolve
so called 'tested software' on many production lines.
So my advice; Synchronize Manually, at least that way you know the data tried to update.
