I have been looking for a decent electrical wiring software....preferably with libraries that include RV equipment such as Batteries, bus bars, Victron shunt, MPPT solar chargers, ...
I was unsuccessful in finding any reference to this here but I'd be surprised if it hasn't been discussed before.
Does anyone have a recommendation? Thanks in advance.
2022 T@B 320S Boondock
2021 Toyota RAV4 TRD Off Road
Ottawa, Ontario, Canada
Instagram: new.t@bventure
0 ·
Here is a TaB wiring diagram example created by or posted one of our members:
Also seems even the big expensive CAD systems are focused on large scale wiring of buildings, airplanes, ships, etc nothing as small scale as a trailer or some electronics cabinet.
At my last two manufacturing engineer jobs the Electrical 'Wiring" design was documented using a common drawing tool with symbol libraries built up over years of usage.
Since our products were smaller than a trailer the Mechanical CAD system was used to show 'cable run' locations in a product (basically pipes of different size/color) to confirm all the worms would fit in the box.
If you guys come across something, do let me know. Thanks!
Here's a tutorial video.
https://www.youtube.com/watch?v=Z0D96ZikMkc
Some notes:
1) I plan to use 10AWG wires for this since this is what Nucamp appears to be using and I do not have or plan to install an inverter.
2) If you plan install a DC-DC charger to maximize vehicle charging, you may need a thicker wire from the front tub to the batteries but I don't plan for this at this time.
3) I plan to repurpose the existing 10AWG(?) wire from the previous battery location to the converter to bring power to the front tub for the safety breakeway device.
4) I plan to repurpose the existing 10AWG(?) wire from the previous battery location to the existing Victron solar charge controller to use for the existing tub mounted SAE solar port.
5) I plan to move the cutoff switch that was in the tub to a location inside that would be easy to access. I believe the new 2023 models have done this already.
6) One day I also plan to install a solar port closer to the new batteries spot to reduce the length of wires and maximize efficiency from my 200W external solar panel.
I don't claim that this is perfect as I went by memory and research done in this forum so perhaps I will have some surprises in the spring when I get the actual work done. I'm willing to change it and re-post it if you spot some mistakes. Your feedback so also very welcome.
I'm in the process doing the same modification except I'm adding an inverter also next to the Air 8 2021 320 Lithium and Inverter Install (vanillacommunity.com) I'm waiting for my cables and high amp fuse to come in to start. I also do not plan to install a DC to DC charger right now. I'm not sure I need it. I also would have to cut a hole in the TAB floor somewhere to get the wires inside since I'm moving the batteries inside. I've been looking to see if I can fish a pull wire where the existing wires go below the bathroom and out to the trailer. I could repurpose the 12V line to the switch, but the AWG is too small. Attach is my drawing.
Southern Maryland
What about the original wire from the original battery location in the tub to the existing Victron solar controller? I assumed it was 10AWG. Can you confirm?
Thanks!
All wire (solar and 12V power) in my 2021 is 10 AWG. Some of the ground white/green wires are 12 AWG. You may have seen an earlier version of my plan to use 6 AWG wire from the front tub to the new battery location. I've shelved that idea when the helpful folks in this forum gave me the idea to splice the WFCO position 6 (not AWG) wire to get the power. I also plan to repurpose some of the wires for the solar plug in the front tub. The number 8 AWG wire on my drawing is a mistake. I plan to use all 10 AWG wire for the new splices. The runs are short and 10 AWG is rated for 30amp service.
I've have also shelved the need for DC-DC controller. I emailed Battleborn and actually got a call back (very surprised.. vs an email response). TheTech. Rep assured me that no damage to the tow vehicle wiring or alternator will occur through the 7 pin trying to charge a lithium battery. He said if you do not have a desire to charge your lithium batteries as you drive, there is no reason to install a DC-DC charge controller. He told me that the burning up alteranator/wire is an urban myth. He cited the victron video that shows an alternator burning up which was not set up for a real life situation. He also agreed with my question that the 7 pin power is protected by a fuse.
Good luck with your project.
R/stuart
Southern Maryland
