How can I determine the glycol fluid level in the Alde expansion tank relative to the minimum and maximum marks in my 2018 320S? Can't see the side of the tank. Tried to take photo of the side of the tank with iPhone without success. I expect there is an obvious answer to this but I've not figured it out.
2018 T@B 320S
0 ·
Yep, use a flashlight . . . remove the cap, shine flashlight down the filler hole . . . level will be easy to see.
You might also consider using a black marker to highlight the min/max lines.
Adventures: 52 Nights: 329 Towing Miles 41,900+
On the Plus side - - ONCE you understand how the Alde System works you will love it!
That's the minimum I would do, but I also added a built-in light/switch & peephole so I don't have to keep un/screwing around with removing the panel..
https://tab-rv.vanillacommunity.com/discussion/comment/172240#Comment_172240
Of course, I also darkened the "NIM/XAM" lines with a sharpee pen.
Nice idea though. It works for tank sensors though, so maybe?
Sight Level Tube on HLT
Something like this could be the winner!
First image from my new glycol monitoring camera. Looking promising. Cheap and easy to use.
Your image looks good enough to do the job, but you might need to try again on marking the level lines. Also, you may need to turn down/off the camera light and install a light behind the tank to back-light & show the liquid level.
PS: Isopropyl (rubbing) alcohol will remove the marker ink, if you want to clean it up.
The perspective makes it hard to read, but you can see the glycol level just below the "high" line- it is parallel to that mark. I resist putting in a light because the "big" idea was to keep this simple. I'm toying with running the cable up to one of the upper cabinets, but for now the whole installation deal is just a hole for the camera end.
(Fixed by Moderator😉.)
Wondering if anyone has come up with an alternative way to secure the compartment cover to make it easier to access rather than the existing screws.
Nice lines, by the way!
Same stuff that holds our EZpass device inside our car windshield, and it's made to allow repeated removal, as we do to share between 2 vehicles. I think our locking tape is about 1.5" long.
"The only place where you start at the top is when you dig a hole"
Rick and Barbara - North Texas
More Smiles Per Mile!
Enjoy doing and sharing mods
