Persistent Overheat Red Fail 2018 T@B 400
I have been plagued with a pesky Overheat Red Fail after a glycol refresh. It has plenty of glycol, the circulator is running, do not hear any bubbles, but it was splashing a lot for a while, and I have had to add more to bring the level back up. I checked the bleeder in the bath under the shower, nothing but liquid comes out, ran it for awhile with tongue up, tongue down. No leaks, am on pavement so would be easy to see. And boosted the circulator to 5 for a while, now back down to 1.5.  But it gets to 160 F and the propane heat shuts off and Red Fail. And note: all the radiators are hot, fluid seems to be moving around fine.  Circulator is still running. Camper is winterized, domestic water drained now, but it was behaving the same for this past season. Yes, though 4000 miles of travel, you would think that would move air bubbles around. Is it the hot water tank going to 176 F causing the Red Fail?
What else can I look for?
This photo was taken seconds after it failed:
T@B 400 2018 Tacoma TRD SR5
