Checked on my TAB the other day as it's been pretty frigid in Gunnison, CO. Anti-freeze is frozen in the toilet so I assume its the same throughout my plumbing. Added some new to toilet and poured down shower and sink. I don't know what else to do, its the nature of the beast here. Keeping fingers crossed until May. Has anybody else had negative repurcusions from this?
0 ·
Southern Maryland
Adventures: 58 Nights: 405 Towing Miles 50,180
see this
https://www.splashwash.com/application/files/9916/4304/5413/RV_Marine_Antifreeze_Facts_10-22-18.pdf
I aim for -20 for the freeze-point (slush), cuz then the burst point is closer to the potential temp. In Gunnison, I'd think you'd want to be ready for closer to -30 or -40 for the burst point.
Not sure if it applies to RV antifreeze, but you can buy 50/50 antifreeze, or you can get 100% that you dilute to your preference. Maybe you could find some 100% and add it to what you have in there. (Make sure they're both non-toxic 'glycol' - as RV antifreeze is)
managed by VE Smart Network
https://tab-rv.vanillacommunity.com/discussion/14537/frozen-antifreeze#latest
If you get a warm day with the trailer in the sun I would try to re-winterize with the Prestone. I would also turn on the Alde heat for a few hours to also help warm things up. You'll know quickly if you have frozen pipes if nothing comes out when you turn on the 12v pump. If antfreeze comes out of the faucets just use a few gallons of Prestone to push out the old stuff and you should be fine.
"Just Enough"
https://www.thervgeeks.com/is-rv-antifreeze-toxic/
https://www.chardonlabs.com/closed-loop-systems/glycol/
Here are graphs of density showing contraction of propylene glycol when it freezes (higher density).
https://ingredi.com/content/pdfs/Propylene_Glycol_USP_TDS.pdf
I thought all RV antifreeze was inherently propylene glycol, and thus non-toxic.
Guess I didn't do my homework!
Edit: thanks for the link @Sharon_is_SAM. Now I've done my homework. Good to know!
"Just Enough"
-RV antifreeze (prop glycol) expands slightly when it turns to a slush. The slush period is termed burst protection.
-When it freezes, it contracts (compared to the slush period)
And @Jay1415, I also didn't realize it actually contracts when it freezes. Thanks for the info!
https://www.atsdr.cdc.gov/csem/ethylene-propylene-glycol/propylene_glycol.html
I believe this started with RV antifreeze for the water system. I drain water and blow everything empty. I don't put in antifreeze because I don't want any residue in the system. If there is no liquid water in the system, there is nothing to freeze. The Alde system will be fine, it was designed for this.
"Just Enough"
Still going to add the Prestone when it comes for good measure.
