Looking for a little electrical math help with testing my inverters capabilities.
At 115V the Air8 is drawing between 6.5 and 7 amps.
So that's 6.7 amps x 115 volts = 770 watts
So, that converts to 770 watts / 12 volts = 64 amps
When I measure the current at the battery with the Air8 running on the inverter I get about 72 amps.
Here's where I'm confused.
If 770 watts / 72 amps = 10.7 volts
Does that represent 1.3V in inefficiencies or voltage drop over the 8' run of 2 AWG wire between the battery and the inverter?
(or more if the battery is at a higher state of charge than 12V)
Am I wrong in thinking that the Air8's wattage is constant at 770W when going from 120V to 12V?
(What might be skewing the numbers a little is that the inverter is putting out close to 120V, but my house is at 115V.)
Your calculated numbers are right..but don't know why the difference
Your calculated power consumption looks close to the spec. number.
Southern Maryland
Air8 calculated demand 770W
Battery measured demand 864W
Inverter eff (770/864) 89%
Your measured value seems correct for this inverter.
That said:
Electricity is measured in units of power called Watt. A Watt is the unit of electrical power equal to one ampere under the pressure of one volt. Watts are power and what we care about, Voltage and Current are just helpful indicators.
The ampere is a measure of the amount of electric charge in motion per unit time ― that is, electric current.
Voltage is the pressure from an electrical circuit's power source that pushes charged electrons (current) through a conducting loop.
The higher power requirement at the battery is because of the inefficiency of the inverter. Nothing is 100% efficient. The inverter is ~90% efficient so to get 770 watts out you need 856 watts in. (770/.9=856)
As MuttonChops said, power management is what matters and voltage with amperage are factors used for that accounting. It appears you system is working as expected.
But overall, you have it correct, just be very detailed in where and how much you actually are using at the same time.
(edited to clear up some implied statements)
managed by VE Smart Network
I find this interesting and trying to get my head around it. I follow everything, but so I'm clear, the 10.7 V reduced voltage is due to a combination inverter inefficiency and wire line losses?
Thank you
Southern Maryland
battery Watts = battery Volts x battery Amps
battery watts is actually 856 (calculated) so:
Vb = Wb / Ab => Vb = 856/72 => battery Voltage = 11.9
that seems like a reasonable value given the 72 amp load and represents what would be expected at the 12v input of the inverter (so includes any wiring losses from the battery to the inverter).
A couple of additional actual voltage or current measurements would help isolate each components contribution to the overall efficiency and eliminate some assumptions made for these estimates.
***For those following the details, power calculations for AC circuits require a power factor to correct for the alternating current waveform or use of a true RMS meter***
Southern Maryland
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
How warm, if at all, did your inverter get when you ran the Air 8 test? I'm just curious, I believe you know from my other posts, I plan on placing an inverter next to the Air 8 (with lithium batteries). I ask not because I'm concerrned about the Air 8, but maybe I should put the inverter where you did for more breathing space if it generates heat.
Thank you
Southern Maryland
Thank you
Southern Maryland
Southern Maryland
I have a 300 watt DC-CD charger that at 6-7 amps is barely warm but pump the load up to 250 and the heat sink really gets hot! Design it for worst case cooling and load. Keeping it cool dramatically improves the life of the product.
