I did a real dumb and plugged my Tab in a 240 volt 30 amp - that I myself had wired. I know, I know. This is 100% my mistake. I have wired plenty of 30 amp plugs in that past and just wired it up as a 240 out of habit. Consider me suitably admonished and please help me out of this mess.
First the good news: I was testing the plug and didn't have anything running. The rig was plugged in 30-60 seconds before I noticed the lights on the surge guard (which, if you didn't know, is not a surge protector - I know this now). I unplugged everything and did some googling to see how much trouble I was in, and luckily, all the appliances that I can test on 12 volts seem to be fine.
Now the bad news: I can no longer run on shore power. I don't have a wiring diagram, so I don't know exactly what might have been fried by 240 volts. From what I have been able to figure out, it looks like at least the converter and maybe the main 30 amp breaker.
We are supposed to leave for the holidays on Tuesday the 20th. We have the solar package, so we can make it work, but I would love to get shore power back before we leave. I am in Seattle and I have Monday to fix this (if possible). Any thoughts?
0 ·
Consider installing an EMS while doing your repairs.
Southern Maryland
The wiring error changed the 120VAC Neutral, system ground, to a second 120VAC HOT conductor.
Normal 120VAC
Abnormal 240VAC
Since the Convertor Board in the WFCO Power Center is hard wired 'on' it is toast and its Circuit Breaker might be as well. Replacement Boards can be purchased . . . just 5-wires to connect.
The Alde, Air Conditioner, and 3-Way Style Fridge - - - if 'off' - - - when the 240VAC was present are most likely Okay. While the 2-way Fridge is hard wired to 12VDC only. Except for the Convertor Board and any outlets on its Circuit Breaker I'd expect the AC Panel to be functional.
Note: Some owners have reported having an Inverter that includes a Shore Power input mode (that way the inverter does not have to 'run' to feed those outlets) . . . so it's possible the Inverter was damaged
Adventures: 58 Nights: 405 Towing Miles 50,180
Based on my read of the electrical diagram, I think the only thing that was energized was the 30 amp breaker, the 15 amp breaker for the converter, and the converter itself. Does anyone know if there is a place to get WFCO breakers in Seattle (or nearby)? Then I could test if we can run off shore power. I probably won't be able to charge the battery, but the solar charger is still running, so we can make do.
Southern Maryland
2020 Tacoma TRD Off-Road
https://tab-rv.vanillacommunity.com/discussion/comment/154789#Comment_154789
Just curious what ended up being the issue?
Hopefully it was simple and everything is working....
Southern Maryland
