I upgraded my single BB to a 3 battery setup with a 3000W Victron Inverter and added an external solar connection.
Now we just need to find a time to escape the frigid north for warmer climes.
2 ·
when the inverter is not used.
Couldn't help myself. It really is a beautiful piece of work. Love the matching arcs of the battery cables. I'll bet the screws for every outlet and switch cover plate in his house all face the same way (as they should).
If you increase your inverter size, you most likely need to increase the fuse protection in the circuit along with possibly changing wires to a larger size wire to handle the load. I say "likely and possibly" because we don't know what you have. To tie a standalone inverter into the the WFCO to send AC voltage to all the outlets when on battery power you need a transfer switch or some sort of switching relay. That is an inverter/charger in the picture, not a stand alone inverter.
Here is a link that explains sizing fuses and wires for an inverter circuit. Click on the orange download button in the upper right corner.
Calculating Inverter DC Wire & Fuse Size | DIY Solar Power Forum
Southern Maryland
You will need to do some rewiring as the 1200w inverter as installed by NuCamp is only an inverter and is wired to provide power to the outlets in the bedside cubby and under the television.
The Multiplus is an inverter/charger and will take over the charging of the batteries from the WFCO converter. 10/2 wire comes into the Multiplus from the 30amp plug. Then a 10/2 wire is run from the Multiplus to the WFCO converter. You will also need to rewire the 2 outlet that were being powered by 1200w inverter.
No transfer switch is required as @Yoshi_TAB stated. All those capabilities are built into the Multiplus.
Here is a diagram that helped me in wiring my system.
