I’m new to Tab ownership and this forum. Just bout a 2020 Tab 400. Everything works fine on power but when I run the Alde system on propane it shuts the regulator off within about 10 seconds This happens as soon as I hit the green flame on the main screen. Fridge and stove work fine until Alde turned to propane
Help!
The Alde system requires a higher propane flow than the fridge or the stove. Possibly the tank is pretty much empty and once the Alde tries to light the pressure drops to nothing.
i did get a response from Alde that it may be the exhaust hose out of the boiler.
still curious if any other solutions
How do you recover from the shutoff ?
What is the outside temperature and where did the propane bottles come from ? While typically referred to as "propane" in warmer states it is often blended with butane which liquifies at -2C.
