Background:
I've now had two water-in-the-cabin events.
The first had about 1/8 inch of water over nearly the entire floor surface.
The second had a much smaller amount, 1/16 inch, over the same general area.
I thought the first event was my fault as I had just used a hand-wand car wash to clean the outside of a very muddy trailer. So I though maybe the water pressure and water angle was too great. We also had a heavy/windy rain downpour between the car-wash and water-the-cabin discovery. And to increase the difficultly the water-in-the-cabin was not discovered until I was on the road. That is the trailer sat for some days with water in it. While I was loading for a trip and there was no visual or other sign the trailer had water on the inside. I generally have the trailer parked for storage without it being level fore-aft. For event one I believe the trailer had been stored with the rear slightly lower - - - so water pooled along rear of bench seat storage area - - - which I did not detect.
Once on the road with the trailer more level and some good road vibration the water was discovered at my first Rest Stop, stop.
Every time it rained after that I would inspect the cabin . . . but never found any standing water. This reinforced my hand-wand car wash theory.
All seemed fine until the second event. Trailer was parked for storage and level. We had a steady 20-hours light rain storm before I hitched up and started by drive. Before hitching up I inspected the cabin floor - - - no water was visual.
However, at the first Rest Stop, there was the 1/16 inch of water.
Current Thinking:
The first event had the trailer sitting after the car-wash washing. The day I discovered the water, during my trip, was a dry day with dry roads.
Each time I checked the trailer after rain storms the cabin seems dry.
I also was camped in a heavy rain while traveling in Montana. During the rain and after the rain no water was visible in the cabin. Special Note: When I left that campsite the roads were dry as it was a few days after the storm.
The second event started with the cabin seeming dry, the water was discovered after driving for two hours on wet roads. You know the ones that have lots spray until the sun dries out the pavement.
So I'm thinking the water is being forced into the trailer while driving or while hand-wand washing.
Wheel Wells are the first suspect. The drive side is dry, the passenger side is wet but I can not determine if that is because that is the point the water-in-the-cabin has been draining or if it is the source. Of course since the water does drain there resealing is needed but how to determine there is not another water source point?
Additional Info:
++ The Alde compartment and Driver side wheel area (WFCO Power Center) seem to be staying dry.
++ There has been water over the entire 'walking area', under the Fridge, in the passenger wheel well, and under bench (non-Adle) area.
++ There is floor damage due to the water. I have had communication with nüCamp and I am still in the process of investigating how much damage and what repairs might be possible.
Request:
How would you find the water intrusion location?
Another idea is too use a leaf blower to pressurize the interior (via a window) of your TAB, then use soapy spray solution to spray around the outside perimeter. The soap bubbles should show up where air is escaping. Good luck
Southern Maryland
Edit:
Here it is..
https://tab-rv.vanillacommunity.com/discussion/2895/attention-special-factory-maintenance-notice/p1
2019 Tundra Crewmax aka Hoss
SE Louisiana
2022 - 11 trips - 34 nights
2023 - 4 trips - 21 nights and counting
2018 BMW X5 xDrive35d (17 mpg towing avg)
2020 Toyota Tacoma TRD Off Road (10.9 mpg towing avg)
@schwartzki, that is crazy that you had a leak around the wheelwell on a new trailer. I have a 2019 and the caulking still looks good, but I check it occasionally since leakage there is a known issue. I keep the trailer covered and stored under a roofed storage facility, so that likely has helped a great deal.
expect re-installing the air-flow shield will be a real pain . . . .
Today I tried the 'light test' . . . . for leak detection
All lights on in the cabin, see if any light is coming out well after dark . . .
But of course there is no smoking gun. Not a big surprise as water will travel a zig-zag path and light won't but it was worth trying.
I have never had any water infiltration prior to our most recent trip. This includes no water penetration in the side bench compartments (where the wheel wells are located), the Alde compartment, or the rear bench/storage area. I specifically checked those areas during our trip and all remained dry. Also, the last time I checked the seals around the wheel well area there were no issues or separated caulking observed.
Unlike your situation, we discovered the water infiltration in the kitchen area within a couple hours (two separate incidents during our trip, but fairly close in time by days.) Thus, we were able to use some towels to soak up the water before it could travel to any other area of the trailer. That particular area (generally below the sink) has always had a slight "soft" spot at one location of the vinyl flooring. However, it is minor and hasn't been something we were concerned about. I suppose we just assumed it was normal with the soft vinyl flooring, but maybe not. But, last weekend we discovered what feels like what can best be described as a "lump" (raised flooring?) in the same area you have described where there is a seam between the two underlayment sections of flooring come together below the interior vinyl flooring. I don't know why that has suddenly appeared. Maybe the glue/sealant between the vinyl and underlayment has failed/separated? Regardless, it was not noticeable when we thoroughly cleaned our trailer (inside and out) after returning from our most recent trip at the end of October. We noticed it for the first time this past weekend.
While I had the trailer home, I also removed the coroplast cover under the frame to take a look at the fresh water tank and plumbing due to a water line blockage. At that time, I do not recall any visible sagging above the axle, but I wasn't actually focusing on that area of the trailer. I happened to take a photo of the the fresh water tank. It is supported by a metal frame and is situated just slightly above the axle (i.e., not resting on the axle.) I do not know if that is how it was oriented when we purchased the trailer.
ALSO, RE YOUR ORIGINAL POST, you wrote: "The drive side is dry, the passenger side is wet but I can not determine if that is because that is the point the water-in-the-cabin has been draining or if it is the source. Of course since the water does drain there resealing is needed but how to determine there is not another water source point?" I am unclear if you suspect the water may be draining toward the passenger side, or if you have actually determined it is "draining" away in that area. IF you know it is draining there, how did you determine that, and where is it draining to? Thanks!
These rest stop 'truck, trailer parking areas' were not level but nearly so.
Both times water was draining, as in a stream of water, from aft of the Passenger wheel well.
At this time I still suspect the draining is the result of seal failures on the inside of the trailer as damaged materials are visible while on the outside I've not found any clear gaps of missing sealant/material.
As noted in early comments - - - rain when the trailer is stationary does not appear to enter the trailer, while driving on a wet road does get water in the trailer - - - So far the one passenger wheel well outside sealant gap (front side) is the only possible water enter point found.
My greatest fear is after months of drying the floor structure and resealing the vinyl back down to the floor structure - - - my next wet road drive will again include water in the trailer.
