Hi All, and happy holidays!
We will be the proud owner of a 2018 320S Boondock next week, and it did not have the solar installed. Some time in the next year, I'd like to retrofit, nuCamp says not recommended, use the foldup panels when you park, but ...
- I'm certain someone on this forum has done it, love to hear the success/war stories!
- Not concerned with a manufacturer warranty; that said, I want to take care not to mess with existing charging and inverter/converter circuitry; maybe I should design it completely separately from the existing 12V system, electrically isolated?
- I have seen folks that have replaced the single 12v lead-acid with 2 6v batteries, is that advisable for more amperage?
- I've done solar installations in my home, for limited 12v purposes and using a very small (800w) square wave inverter and lead-acid/AGM batteries in parallel, nothing huge, about 400W total solar output
- Thinking about replacing the existing 12V Lead-Acid battery with LFP, which is something like 3x "energy density" over L-A, has anyone tried that? There is a glut of EV batteries around on the used market, as another option, obviously it would be a *very* bad idea to locate batteries with a capability of catching fire next to the propane tank, so I'm currently thinking a location elsewhere would be preferable. Under the sink?
- Any tips on fastening a flexible solar panel to a Boondock without doing body damage, or having it blow off on the road? Routing the wires?
Thanks in advance!
Al
https://tab-rv.vanillacommunity.com/discussion/8869/my-solar-install-clean-and-simple
Whether or not you need more battery capacity is pretty dependent on where and how you camp. I used to think I *needed* more battery capacity (preferably lithium), until I ran a test last year and discovered I only use 6 to 9 amp hours a day, boondocking with a propane fridge…which is pretty easily recovered in just an hour or two of decent light with my 200 watt portable panel. Turns out my current single 105 ah AGM is plenty for the kind of camping I do.
LFP batteries are NOT as prone to fire as the lithium ion batteries typically found in electric vehicles…I would not use LI batteries in a small trailer, because no matter where you put them, they’d be close to both the propane and your bed.
I have a 2017 model t@b with it's 3 way fridge and while on propane the fridge sips power. I did upgrade my battery to a group 31 110 ah when the battery finally needed normal replacement. We have boondocked up to a week with that battery and a very small 80 watt portable suitcase placed in a relatively sunny position while in the PNW in summer. It is doable depending on your weather luck.
Take possession of your new (to you) trailer and assess it's equipment and your camping style. A new larger capacity battery bank and simple portable solar panel may be all you need.
Good luck with this, although I'm pretty sure you don't need luck and have already acquired the life skills. Happy t@bbing!
North Texas - Retired Air Force
Trips - 46 Mileage - 58,461
