The top hinge on the bathroom door broke and I am trying to find a replacement. It looks like a kitchen cabinet hinge but Lowes didn’t have a match. Has anybody needed to replace one? We are on a three month trip.
Jeff & Amy
Now in Manistee, MI
1 ·
2013 Tundra TRD 5.7L
Massachusetts
Massachusetts
lesson learned that the door is heavier than the design of the hinge. so we bolt the door while traveling now.
Massachusetts
2020 Tacoma TRD Off-Road
Just returned from four months to Alaska and we broke at one time or another every hinge on our bathroom door. We have a 2019 t@b 400 and the trip around the bathroom entrance was black plastic. If you try and tighten the hinge you end up cracking the plastic. Nucamp no longer uses the black plastic but now white aluminum. I had this installed with new hinges and haven't had a problem. The hinges themselves were pretty cheap from nucamp, so I carry a few for emergencies but I think the aluminum trim will make all the difference.
I know this is an old thread but since I found it helped point me in the right direction, I thought I’d post some new information to help those looking for replacement hinges.
In my 2018 TAB 400, I noticed that all but one wet bath door hinge was broken. Since the originals used cheap cast metal at the frame attachment I wanted to find something better, rather than replace them with ones likely to fail the same way.
I found these stainless steel hinges on Amazon. They fit perfectly and I am hoping they will be much more durable.
KONIGEEHRE 10 Pack Soft Close Cabinet Door Hinges for 1/2" Partial Overlay Cupboard, 100 Degree Opening Angel, Stainless Concealed Kitchen Cabinet Hinges with Mounting Screws and Manual
https://a.co/d/hz8jdf7
