How to open trailer J box
Yoshi_TABYoshi_TAB Member Posts: 541
Hi,
I'm looking for some hints on how to open the trailer junction box.  I've done a minor re-wiring effort to install   an  inverter and lithium batteries inside and I want to confirm the #6 pin in the box is getting power.
I can feel (although I can't see it) that there is a tab on top of the j box that maybe you press.  But before I go and and possibly not do it right (i.e break it) , I thought I'd check with others.
Thank you
2025 360 CS
Southern Maryland
  • MuttonChopsMuttonChops Member Posts: 1,862
    Are you referring to the 7-Pin Cable Junction Box mounted on frame?
    The cover is held in place by two large Phillips or Hex Head bolts . . . at least that was the case up to model year 2019 . . .
    The Bolts are at the Red X positions on the cover:
  • Yoshi_TABYoshi_TAB Member Posts: 541
    Hi,
    Yes, that's them.  I see them now, they are recessed below flush and did not see them w/o a flashlight.
    Just curious, is there any sealant or rubber gasket between the cover and the box?
    Thank you,
    2025 360 CS
    Southern Maryland
  • ScottGScottG Administrator Posts: 5,624
    There might be a gasket in the cover, but I don't recall for certain. Either way, I've never had an issue removing and reinstalling the cover. There is nothing you have to clean off or replace.
