Outside Shower Replacement-2017 320S
I have to replace my entire outside shower unit (broken part) and have one on order from NuCamp via my dealer. It’s really a “plug and play” unit and I dislike paying for service if I can do it myself. I also don’t want to damage the Azdel by doing it myself. I would imagine that there needs to be some sort of sealant involved. Has anyone here done this, and how did it go? Thanks!
  • Horigan
    Horigan Member Posts: 891
    edited February 2023
    Any outdoor sealant or chalk will work.  I use 3M 4200, because that's what I have around.  Any RV or marine store will have something.  If you prefer the existing grey, check an RV store.  You should consider replacing the stiff white shower hose with a more flexible one.  It will be easier on the area that failed.
    It's easy to replace.  Just gently scrap off the old sealant with a putty knife, unscrew the old unit, move the hoses to new unit and re-install and reseal.  Make sure the pump is off before starting.
    https://www.amazon.com/Camco-43716-Marine-Flexible-Replacement/dp/B000NOSSEI/ref=sr_1_5?keywords=rv+shower+hose&qid=1677169505&sprefix=rv+shower+hose%2Caps%2C295&sr=8-5
    Rich
    2019 T@b 400
    Bellingham WA
  • Homebodyatheart
    @Horigan thanks for this information! I almost never use it, but it needs to be functional.  :)
  • Slackers
    Slackers Member Posts: 490
    I too had to replace my unit.  I did the same as @Horigan. I used Geocel 2810V Pro Flex (White) RV Flexible Sealant. It was purchase on Amazon and has held up well the last couple years.
  • Homebodyatheart
    @Slackers how difficult was it to remove the unit? It’s still winterized, probably until late March or April, so no issues with water in the lines. I hate the thought of paying for labor if I can do it myself. Thanks for your input!
  • Slackers
    I used a plastic putty knife to remove the caulking.  I used the blade flat against the wall and then flat against the shower box enclosure.  Don't go after it like a horror movie villain.  After that effort and the removal of screws the box could be pushed out from the inside. I used rubbing alcohol to clean up the residue.  In general just slowly work through the process.
    Also as @Horigan notes above attach the hoses to the new box before tightening down the screws and sealing with caulk.
    qhumberd Administrator, Moderator Posts: 855
    Not sure but if you have the Fontana outdoor shower box you might consider making it more useful and less prone to leaks with an inexpensive mod as I and others have done:
    https://tab-rv.vanillacommunity.com/discussion/16114/quick-disconnect-for-the-outdoor-shower-a-success#latest
  • Horigan
    @Homebodyatheart
    The link above at a minumum will give you a good idea on what's involved to remove and replace the shower box.  Just four screws once the sealant is removed.
    Rich
    2019 T@b 400
    Bellingham WA
  • Mickerly
    Mickerly Member Posts: 486
    As Horigan suggested, the hard white hose is a pain. I replaced it with a regular flexible shower hose. Also, you can takeoff the sprayer. It has a very small entry hole for water. Opening it up to 1/4in makes it work so much better.
    2018 320CS-S
    "Just Enough"
