The batteries in my 2020 400 are no longer holding a charge, after about 3.5 years, which is a drag since we didn't even use them so much. We always ended up in places with power, save the occasional overnight at a Walmart.
I think the short life is due to me keeping it plugged in all the time when at home, under the carport? Never ran them down.
Is changing them a simply a matter of unhooking the old, pulling them and dropping in the new? If it's a more complex procedure, is it here in the community somewhere? (I have been searching; not quite content with answers.)
Also, are there some cheaper options for someone who doesn't boondock as much? There's lead acid, but even with the vented compartment those would be right under the bed. :-/
- Virginia
- 2020 T@B 400
- 2018 Tacoma SR V6 3.5L
0 ·
2006 F-150
Coeur d'Alene, Idaho
What you're looking for are two 6-volt batteries in the 190 or greater amp/hour(AH) range in size GC2, and you'll need to buy 2 of them. Two 6-volt batteries properly configured equals the required 12-volts. The original (2019 at least) batteries were 224 AH. Here's an example of what you need made by Duracell: https://www.driveduracell.com/pub/media/wysiwyg/1688.pdf Just make sure that it says AGM on it and is size GC2 and it should be a direct replacement. Other good AGM brands are Trojan Motive https://www.trojanbattery.com/products/t105-agm-6v-battery and Lifeline https://lifelinebatteries.com/products/marine-batteries/gpl-4ct/
Less expensive AGM batteries are also available that may not have nationally-familiar brand names. They may also have less amp hours of power available than those I noted.
2019 T@B 400 BL
2021 Toyota Sequoia 4WD
My 400 came with the dual 6V Harris HBDAGMGC6-A 's. I had opened up the compartment back when I first got the camper, so knew how to open it again for the fateful multimeter test.
I read something about the lithium batteries also requiring a new converter or some such. Anyway, the AGMs are really all I need.
Here's a pic of the battery compartment a couple of months after we bought the TAB. I was installing the Victron battery monitor. (Note the white junk around the positive pole of the right battery. Didn't think anything of it at the time.)
Finally, when I swap them, should I just have the battery switch off and that's it? Plugged into shore power or will that cause a problem? I imagine I will be resetting all the Bluetooth settings for the solar and Victron BMV afterwards.
Once again you all are a big help!
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
What is asking for all this power? Carbon monoxide detector? Converter? Any fuses I should pull?
I would also really confirm nothing is turned on in your system. It sounds like you may have a short somewhere in the system. Do you have a multi-meter? With the battery disconnected and the battery switch off, is there any resistance other than open circuit between the positive and negative battery cables, not attached to the battery? It should read open circuit (infinite resistance).
Time to sleep on it I guess.
- Alec
THANKS EVERYONE!
