All we recommend is that your replacement tires be the same specifications as the factory ones. The PSI we suggest will be posted on the VIN sticker on the sidewall of the unit.
Typically RV Tires don't require balancing, we do not balance them here.
and... ACTION!
So, I am determined to keep to the 50psi tire pressure that the original tires came with.  I am not at all convinced that using Goodyear Endurance is a good idea -- they are proud of the sidewall stiffness of their tire... with extra stiffness AND extra inflation pressure (65 pounds recommended/required) it seems like an invitation for more transmitted road vibration and impact to the trailer itself.
The best tire I can find in the right size with the right tire pressure is:
Maxxis M8008  TL12460000  205/75R14
I think I would have them balanced, as in "no harm done..."
Comments or suggestions???  and love to all...
Lower tire pressure can also affect the temperature, though there's a possibility that the 65# pressure spec with the Goodyear tires might be only their recommended max inflation pressure. Likely you can run a lower pressure.
Tire choice is a personal thing and should be based on how you trailer is used. For example, we use our 320 for state park camping and travel on the highway. A tire build for speed and road use, like the Endurance is a good match. If you driving a lot on dirt roads, I would lean towards a more agricultural tire like the Hercules (made by Cooper tire sold through tractor supply and feed stores) intended for on and off road.
Like batteries, tires come in many different designs and levels of quality. Rather than trying to match tire pressure, look for something based on how you use your trailer. A two year replacement seams short. What is happening with your original tires?
"Just Enough"
However -- it seems to me that there must be a "three little bears" right stiffness for our NuCamp T@B trailers. Two things, other than the manufacturer, affect stiffness -- the tire pressure, and the tire design load rating. Our OEM has a C rating. I don't doubt that a D or E rating means more stiffness to deal with intended greater loads. That isn't inherently good. On top of that, the Goodyear Endurance brand brags about tire weight and sidewall stiffness -- AND comes in a minimum D rating in our size. I found a Youtube (don't laugh at me...) video of someone with a 5th wheeler who replaced his tires with Endurance tires and took before and after videos of his trailer underside while running on the highway. His comment, pretty much... "the trailer spends more time in the air now!!!"
The 320 non boondock suspension seems ok for intended use, but I, for one, am not looking for additional road vibration transmission.
Goodyear (and pretty much all ST manufacturers) recommend you run their tire at the maximum cold inflation, as far as I can tell.
I would be really uncomfortable running a tire designed for 65 psi at the greatly reduced NuCamp recommended 50 psi. Frankly, given Creed's advice, I'd be uncomfortable running anything but a C rated 50 psi maximum ST tire -- which is why I started this discussion. Just looking for the best one, or someone to talk me into a totally different mind set.
My 2020 320S came with one tire manufactured in 2017 and one in 2018, so the older tire is now 5 years old. I'm not racing out to buy new tires, but, given the age and the low-endish reported quality of the OEM tires, I am starting to plan on replacement. I'll likely do it in the fall, after my third year of use.
"Just Enough"
"Just Enough"
Yes, I wish they were made in the USA, but this seems to be as good as it gets for now.
Again, thanks all.
"Just Enough"
