Lead Acid to AGM
dp150
Member Posts: 18
2015 T@B 320
Question: Can I simply change my old lead acid battery out with AGM? No concerns with charging system in camper?
Thanks
Thanks
Don & Michelle
2015 T@b S. 2017 Nissan Titan
The WFCO converter will be fine, but you may want to check with your battery manufacturer for the best setting of the MPPT solar charge controller.
Shouldn’t be an issue. If you have solar, you may need to check the settings on your controller, but as far as the converter on the trailer goes, no changes needed.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW2 -
Agreed. No changes needed to trailer.2018 320CS-S
"Just Enough"1 -
You might consider getting a Noco genius or similar charger to occasionally maintain and fully charge your new AGMs for better performance and longer life. Not essential... just better. And no change to trailer as wished.Yanni Lazarus 2020 T@B320S, 2018 RAV4 Adventure, Central CT0
