The Victron connect(android) worked last fall when I took the battery out. I put the battery back in and the solar is charging, but the app won't find the device(Victron MPPT 75 10. I did all of the recommended trouble shooting except restart the controller, Can't figure out how to do that. There is no reset or off button that I can find. Turning the battery switch off doesn't disable the controller. Any suggestions? Thanks.
0 ·
2019 Tundra Crewmax aka Hoss
SE Louisiana
PIN code lost
If you have lost the PIN code, you will need to reset the PIN code to its default PIN code. This is done in the VictronConnect app:
Navigate to the device list of the VictronConnect app.
Enter the solar charger's unique PUK code as printed on its product information sticker.
Click on the option symbol next to the solar charger listing.
A new window will open which allows you to reset the PIN code back to its default: 000000.
SE Louisiana
This is all I can provide, but I assume you've already tried this. Did you find the orange refresh button?
The controller is missing in the VictronConnect device list
Some steps to try to resolve this issue are:
Press the orange refresh button at the bottom of the VictronConnect device list and check if the solar charger is now listed. Only one phone or tablet can be connected to the solar charger at any given time. Make sure no other devices are connected and try again.
Try to connect to another Victron product, does this work? If that also does not work, there probably is an issue with the phone or tablet.
Rule out any issues with the phone or the VictronConnect app by using another phone or tablet and try again.
If still unresolved, refer to the VictronConnect manual.
SE Louisiana
SE Louisiana
managed by VE Smart Network
2020 V6 Chevy Colorado
I suspect the controller is either under the center section of the bed, in the Alde compartment under the bed, or under the closet/3-way fridge. My 2019 didn't come with solar, so don't know for sure.
I've had this issue pairing headphones with my android tablet, if the phone was already paired to it.
SW Montana USA
