Plugged into shore power at home. Trying to heat water without heating camper since I'm in Florida. What settings do I use? I'm exhausted and can't think after 6 months of dealing with aftermath of Hurricane Ian. Aldi is on (green light on power, electric set on 2. Propane off. Tried with thermostat set at 60, then 80 but water is not hot. Aldi 3010
2018 T@B 320s, 2013 Toyota Highlander
0 ·
I guess after six months of dealing with hurricane aftermath in an area where over 50% of homes are destroyed, and 40% of the rest have severe damage, I can handle a cold night with no shower. I'll throw in an extra quilt, and a space heater, and look for a campground but they are few the second night of the trip back to Ohio.
I had great Florida camping plans for the season with my new to me camper . But camper ended up being a safe place to sleep for the first month I was in Florida. And a guest room for friend who came down to help during the worst of it.
I should have tested hot water sooner but it was a low priority compared the rush to complete hurricane repairs before heading north. My neighborhood is toxic.
Moldy, vermin infested homes are finally being demolished.
My Florida place can be repaired but it will take years. It is almost impossible to find contractors. FEMA and county government cause more problems than they resolve at an individual level. They've done well at debris removal. So many elderly people lost everything and are couch surfing. FEMA mostly provided very unsuitable campers for elderly people and almost everyone ended up sending them back to FEMA. Six months after Ian and only a handful of people have habitable dwellings.
Shocking and mind numbing what a cat 5 hurricane and a multiple tornados do to a vintage mobile home park.
In 2 hours I lock the door and leave it behind for a while. I have functional roof, walls, and floor. My seventies era mobile home is battered but survived Ian. I know I'm extremely lucky compared to most.
Maybe I'll get lucky and the Alde will.work on the road. Otherwise I'll figure it out in a few weeks.
Thanks for the responses. It's a relief that I seem to know how it is supposed to work.
WFCO control panel fan ran continuously when I plugged into shore power until I disconnected the battery. From what I see on the forum, that's normal while the battery is charging.
I'm a bit thrown by Sharon's comment:
If your battery switch is on, you will get the Alde panel to energize, but the Alde will not heat water when electric is chosen as the fuel source.
(Specifically, does that also apply to Alde heat when electric is chosen as the fuel source?)
I'm so happy to have a break from the Hurricane Ian mess. Hopefully I'll be ready to figure out the TAB in a week or two.
Thanks again, everyone.
Close the LPG tank, then very, very slowly open the tank. If opened too quickly there is a valve that stops gas flow. Check for leaks around the LPG feed line. You may have air in the gas line since your propane was disconnected. Light the stove and let it run for a couple minutes to clear any air. To clear the “gas failure” message, turn off the Alde, disconnect from shorepower, then turn the battery switch off for a few minutes, then turn the battery on, then turn on the Alde.
BUT, in the event that the Alde 120V electrical plug is not plugged in for some reason (e.g., it can sometimes come loose if not secured in place - - - I use zip ties to prevent that - - - see photo below), the fact that the control panel lights up can mislead you into thinking that you have 120V AC power to the Alde, when in fact you don't. Thus, under that scenario, when you select "electric" for heating (the trailer cabin and/or water) you "think" you have turned on the electric heating element(s) in the boiler, when in reality all you have is 12V power going to the control panel.
If you select propane as the heating source, you don't need a 120V electrical connection, but you still need the 12V battery connection to power the control panel and to ignite the propane burner. This is how you are able to heat your trailer while boondocking without 120V electrical power.
Finally, if you have both 120V AC electric and propane available as sources of heating energy, the Alde control board will select the power source from what is available with priority given to electrical power by default. If there is an electrical power failure at the campground, and you have previously selected both electric and propane as the energy source, then the Alde will automatically switch to propane. A nice feature to have when electric power goes out in the middle of the night while you are asleep.
NOTE: If you prefer, there is a "Prio" (i.e., "priority") setting on the control panel (refer to the Alde manual for specifics) that will allow you to change the priority to propane.
Here's an image of the display screen from the Alde manual. The screen displays an electrical plug icon ("E") when 120V is connected to the furnace.
The standby screen lighting can be adjusted, if desired, so that the display is not always visible. For example, you may want it to be dark while in standby (e.g., when visualizing the display is not necessary, you are not using the display to adjust the settings, or at night while sleeping. See "Background lighting" in the manual for directions on how to adjust the three available modes: Dark, Bright and Invert. I have mine set to "Dark" so that when I press the screen or menu button, the screen comes on, but then turns off after 30 seconds if the display is not touched.
