Alde ?
This been addressed before, but I can't find it in the search. Is there any way to calibrate the Alde thermometer? It's always 5 to 6 degrees high. This thermpro is very accurate. Temp left/ Humidity right. There is a temp offset adjustment, but that is just the difference between actual temp and when it turns on.
  • BaylissBayliss Member Posts: 1,377
    edited May 2023
    @GregChris, you will need to do a temperature offset using the Alde control panel and your independent thermometer.  You can review that info in the Alde owner's manual (section 2.8 and 2.9 in my manual, but may differ depending on your year T@B and Alde model), but here are a couple  discussions about how to do that:
    https://tab-rv.vanillacommunity.com/discussion/16482/heating-issues#latest
    https://tab-rv.vanillacommunity.com/discussion/10196/does-your-alde-hold-at-temperature-other-than-set-point
  • GregChrisGregChris Member Posts: 190
    The offset adjustment doesn't correct the incorrect temp reading. I know I need to set the Alde 6 degrees high to get the desired temp. When a heating unit costs this many $'s and has this much maintenance(the glycol every 2 years), U-camp, and any other company using it should require better standards from the manufacturer. When you spend $30,000 plus for a camper it should work as advertised. I know I seem to be nitpicking, but come on.
  • SlackersSlackers Member Posts: 484
    With our 320 there's a significant temperature difference moving from floor to ceiling. I learned this using another thermometer. The Alde t-stat is closer to the ceiling so it reports a higher temp.
    The 2 thermometers were right next to each other for 5 min. That position is the hottesst point, above the tv, in front of the microwave, and high up. I turned the air8 on, and it had the same temp showing as the therm pro in the photo, the alde is 5 - 6 degrees higher. We like to sleep at around 64, so I set the alde at 70. The actual temp was 62 when we got up, so I don't really know if it even turned on. Didn't hear anything running during the night. How quiet is it? It got down into the mid 40's at night, so I'm thinking it must have run at some point.
    Alde running makes an easy-to-sleep-through hum.
    Not sure where its sensor actually is, but the temperature in trailer is all over the place. Boiling coffee water early in morning raises "kitchen" area 3 or 4 degrees relative to bed or kitchenette. We set Alde at 66 degrees and whatever the temperature actually is, it's a whole lot better than 28 degrees outside (last early Friday morning, Apache Creek, NM)!
    @GregChris, I am unclear as to how you are setting the temperature offset.  Using your photo above, are you setting the offset so that the Alde display reads 6 degrees lower?  I believe that is what you need to do so that the Alde matches the 69 degrees shown on your Thermpro thermometer.
    You may want to start off by first resetting the Alde to its original factory settings.  Then, compare the displayed temperatures (Alde display vs Thermpro) and make the offset adjustment as necessary so that the displayed temperatures match.
    I made a one-time adjustment to mine and it has remained accurate thereafter.  If it still does not work after a "reset," then maybe it is time to call Alde for additional suggestions or possible replacement under warranty (you did not mention the year/model of your trailer and Alde, so I do not know if the warranty still applies.)  Good luck.
