Ultimate Toys vs T@B CS-S?
Hello all, we're new to trailer camping and looking at picking up a T@B CS-S BD and it seems just about perfect for our needs. In researching options I came across the Ultimate Toys teardrop and the extra foot of width seems attractive. Wondering what the collective wisdom is about these UT trailers relative to their T@B counterparts in terms of build quality, features, and infrastructure.
I understand the UTs don't have the ALDE system, and wondering what the UTs have and how it compares in durability and ease of use.
I don't see mention of a solar system in the UT spec sheets I'm seeing, but the ones we're seeing on the Apache lots in the PNW seem to have solar. Wondering if the electrical systems, battery controllers, etc. are shared or different.
Any other notable differences other than the width & the weight?
Any folks out there have experience with both and willing to share their wisdom with a newbie? TV is a 2016 Volvo XC60 3.0 with factory tow package. 3500 lb. GVWR and 350 lb. hitch weight rating. I reckon it'll tow either without drama.
We're lucky enough to be in Seattle so can get to different Apache Camping Center locations to look at both kinds.
Many thanks from the PNW!
2023 T@B 320 CS-S | 2016 XC60 T6 3.0 AWD | PNW
  • gulfarea
    gulfarea Member Posts: 524
    After having 2two 320 T@B,S I don't think to much of the Alde system because of its maintenance! I have looked into the toy hauler and like what I am reading. Art
    2019 TaB 320 S Boondock Edge
  • VictoriaP
    VictoriaP Member Posts: 1,496
    edited May 2023
    Agree with @gulfarea, it’s not a popular opinion around here, but the Alde to me is the biggest pain point on my Tab. The maintenance is expensive, and for many people like myself, it’s not a DIY project. Maintenance on a traditional RV furnace is pretty simple by comparison.
    Yes, when it works, it is a relatively good performer (very slow to heat in colder weather, which is a drawback unless you have a trailer model that includes a CoolCat A/C with its heat pump for supplemental heat). The biggest pro for the Alde is how quiet it is. But to me, that’s not enough to make up for having to spend several hundred dollars at the dealer every two years for maintenance, or even more should something on that overly complex system go wrong. And with Apache, you can anticipate a 6-8 week wait just to drop the trailer off for those appointments, plus 1-2 weeks of leaving it there. Plan accordingly.
    Plus, heaven forbid it fails on the road. Mobile RV techs generally can’t assist with it, and unlike traditional furnaces or the most common Truma products, they don’t stock parts. The good news is, we do have quite a few people here on the forum who can help triage any issues.
    But for me, never again. I’ve had my eye on some used Roadtrek class B’s at halfway decent asking prices and walked away because of the Alde…and ONLY because of the Alde.
    As far as the UT versus the CS-S, I think if I were looking for a clamshell, I’d absolutely go with the UT for the extra space. Every inch counts when dealing with such tiny rigs. From what UT owners have reported, the model seems to be on the same level quality-wise as anything else built by nuCamp.
  • Marceline
    Marceline Member Posts: 1,779
    edited May 2023
    I think that the main difference is the kitchen setup. I'm a bit skeptical about the redundant layout but I can see how it would be cool if you use the camper for things like tailgating and music festivals. I have an older CS-S that came with an outside TV and I eventually took it out as I found it annoying (always worried about smashing the TV screen with things on the counter when I closed up for the evening).
    I think that with the UT you're giving up a lot of storage room for clothing and personal gear because there's both a fridge (inside) and a cooler (outside) and a stove (inside) and grill (outside). One of the main selling points of the CS-S is the storage space available inside thanks to the dresser up front.  The wider body would make wheel-to-wheel sleeping a LOT more comfortable in the UT, though.
    My older CS-S doesn't have the Alde system, and I would be so much happier if it did. I know people complain about the maintenance, but I mostly camp without hookups and since I don't have the Alde I don't have hot water. It looks like the UT has a 120v (not propane) water heater ("Bosch 2.5 Gal. Water Heater").
    My guess is the basic electrical system is the same.
    Everyone uses their camper differently. I think you should think about how you plan to use your camper and pick the one that best suits your needs.
  • Slackers
    Slackers Member Posts: 490
    For us the CSS is the ultimate. We haven't had an issue with the Alde.  We refreshed our Century fluid at home. Inspection of the hoses and connections have surfaced no problems.  As recent tent campers any heat is good heat and we can fire up the Alde while outside so we don't have long to wait for it to warm up the space.  Both of us are 5'-8" or shorter so don't need anything wider.  I can take or leave the rear galley TV but have enjoyed it on occasion. We'd never trade the interior drawer space for a seldom used inside galley. We're happy as clams with our CSS.
  • FreewheelinFranklin
    FreewheelinFranklin Member Posts: 13
    Thanks for all the great info, everyone.
    We went and looked at both, as well as a couple of 320 S trailers, and ended up purchasing the CS-S. We didn't feel we needed the extra space of the UT, and the second kitchen wasn't a plus for us. The UT does have only a 120v Bosch water heater, so as Marceline mentioned you need to be on shore power to get hot water. We figure on boondocking much of the time so that was a plus for the T@B. And we don't really need one teevee so a second one out back was over-overkill.
    I'm 5'11" and I'm a snug fit lying wheel-to-wheel in the CS-S but it was comfortable, and we felt it was plenty spacious for the two of us and our corgi.
    Looking forward to getting it out into the woods!
  • dragonsdofly
    @FreewheelinFranklin welcome to the forum and congratulations on your trailer.  Post a pic when you get your rig. We love pics here. Happy t@bbing!
  • Marceline
    Congratulations! Welcome to the clamshell club.
  • Slackers
    Congrats @FreewheelinFranklin !
    Beautiful trailer and excellent work on your mods @rfuss928 !
    Thanks for the detailed description, @rfuss928. Hearing from someone who's had experience across the range of years is really valuable. I'd seen your rear peninsula table mod and plan on shamelessly stealing that idea for our CS-S!
    We're picking ours up Friday and will post some pictures once we get it home, and out in the woods!
  • jbajor
    jbajor Member Posts: 233
    I have had our UT for almost a year now and absolutely love it!!!  the extra width is fabulous particularly being 6'2"!  WE love having two kitchens... the grill in back is a treat while making sauces in front.  Solar is the same 110w of the tab 320's.  Propane furnace is wonderful.  The ONLY downside of not having the Alde is no hot water without 110v.  I have found that it keeps warm for a day or more in the tank for doing dishes.  Any warranty issues are taken care of by nucamp...  EVERYONE wants a tour inside!
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
  • jbajor
    BTW, my TV is a Volvo XC40...  It tows wonderfully.  I recently added the Polestar upgrade and the extra torque and redistributed shift points make it even better!
    Volvo XC-40
  • DebInOregon
    DebInOregon Member Posts: 1
    Please, we are new owners of a secondhand 2019 tab 320 cs-s - outdoor kitchen to be clear. Is there any way to set up full time sleeping even twin, AND have the Lagun dinette table out full time as well? Hours of searching still hasn’t led me to a firm conclusion. Thank you in advance!
    Some folks have managed to set up dual twin beds in the CSS by creating a leg extension on the passenger side.  Then you could keep the Lagun set up as a table between the bunks.
  • AUTiger83
    AUTiger83 Member Posts: 13
    Looking at an Ultimate.  But the Bosch 2.5 gallon point-of-use water heater is what's bothering me.  How do you take a shower with 2.5 gallons of hot water?
    pthomas745 Administrator, Moderator Posts: 4,695
    edited January 17
    The Tabs have an Alde setup with a 2.5 gallon tank (approximately).  The idea in the Tabs is the hot water from the hot water heater is fed through a "mixing valve" that drops the very hot water with cold water, preventing any scalding problems.  The mixing valve helps extend the amount of "warm" water available for showers.  You still won't be able to hang out in the shower for very long, in any case.  There are limits on how much water is available if you are not camping "with hookups".  The fresh water tank only holds so much water, and the gray water tank has to be managed, also.
    If you are not familiar with this, most owners are good with a "Navy shower", where you spray your self down , turn off the shower nozzle, soap up, then turn the nozzle back on to rinse off.  This saves a lot of water from the fresh tank and helps keep the gray tank levels reasonable over time.
    This "mixing valve" is in the Tabs, but I honestly am guessing whether the Ultimate has the same sort of "mixer".  I can't imagine it doesn't though.
  • jbajor
    Yes, UT has the same mixing valve. I kept our water heater turned up 3/4 do there is plenty of hot water for shower. Do note that you need to be on electric hook up for the Bosch to operate
    Volvo XC-40
  • rfuss928
    rfuss928 Member Posts: 1,192
    edited September 3
    Ultimate Toys front kitchen counter compared to 320S.
    The added width is most visibly evident in this area.
