Lathes for Tab 320CS fell off
racheldagovitz
Member Posts: 5
Hi all, Not sure if this goes here. I had my camper out for its second trip. When I packed up yesterday to drive home, I saw that the latches that go on the inside rod to secure the hatch door had fallen off. I'm sure at least one was there when I left home. So, the result is that I can lock the hatch, but it can be lifted up anyway because the inside catch mechanism is missing. Luckily, I had a bike lock and chain and secured the hatch for the drive home.
I called the dealer and they don't seem to have that part and I have a big trip in a week. Has anyone solved this in a creative way without a Nucamp part. It looks tricky because the rod is four-sided.
Thanks,
Rachel
Thanks,
Rachel
Those latches are widely used on pick-up truck caps. Maybe a local shop that sells/makes them can help...1
Oh, this brings back memories! It’s called a cam. Search for T handle door lock cam or straight cam lock.https://tab-rv.vanillacommunity.com/discussion/5093/cs-galley-hatch-lock-near-miss
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1 -
And when you get them secure the set screws with some Locktite.2019 Tab 320 CSS, 2019 Ranger TV, OH1
