Working from the T@b is a long term goal that I am pecking away at slowly, but surely. One of the biggest challenges I face is connectivity for both Internet and cellular. I need to be online, all day, every day that I am working. There are 2 scenarios that I need to prep for in order to go FT: connected via WiFi, whether it be a campground or a library, and connecting via the mobile hotspot on my phone.
I did a moderate amount of research and borrowed from the knowledge and experience of the Technomads and Gone with the Wynns.
Wi-Fi
My set up is partially complete. The Wifi Ranger is the mostly highly recommended set up by most Rvers. It is also a little more expensive. The second part is a Ubiquiti Nanostation M2 that I planned to mount to a flagpole. Truthfully, I was not planning to invest on Wifi CPE this year, but found a great deal on an open box item from Amazon, that did not appear to have been used at all, so I snagged it.
The Nanostation M2 was reported to have been difficult to set up. It really was not, difficult, at all, but if you do not the difference between a static and dynamic IP, it might be above your paygrade. But, it really is not complicated and if you are a little bit savvy, you can figure it out. I followed this Youtube tutorial and it went off almost without a hitch. I think he said the IP address incorrectly at one point, but I was able to figure it out fairly easily.
So, here is what my set-up entails:
I am giving this a test run at home and so far, so good. I notice some speed degradation, but I think that is fairly predictable, given my home WiFi has to go through several walls, including external brick. Line of sight is a key factor, regardless of which Wifi radio option you pick. In addition to mere connectivity, you create your own SSID, giving you more security.
So far, I am happy with this solution, but need to do a more in-depth testing to determine if it was worth the investment. Depending on the results of the test, I might not need the WiFiRanger.
Cellular
If you have traveled the Southwest, you know how spotty cell service is, away from cities. I need cell service for conference calls as well as for a back-up data hotspot. I picked up a Weboost 4G-S. The research I did on cellular boosters led me to make a decision now rather than later because it appears as though although new technology will be available soon, none of it offers a significant improvement and the prices for the current batch of devices seems to provide a better overall value. Weboost, formerly Wilson Electronics, has long been the favorite in the RV world in terms of RV boosters. I picked up a window mount for the antenna.
My local tests are not really great indicators of the performance of the Weboost, as cell service is fairly good in most areas of the east. Check back for an update later this fall.
I have some time to work out the bugs and am looking forward to a more rigorous test this fall.
I have done pretty well at McDonald's, actually. I have noticed a lot of other restaurants offering it, too.PXLated said:WiFi...
McDonalds, really? Slow as molassis at every single one I've been at.
Grocery stores with Starbucks inside aren't too bad.
Most libraries leave their wifi on when they're closed so if you can get close, it works pretty well.
Surprisingly, in smaller towns, one of the churches sometimes have open wifi.
I read they are going to start throttling the speed. I hope they get penalized or a court order stopping them.larrygon said:I am grandfathered in Verizon's all I can eat data plan. If you cannot get a Verizon signal then there isn't a signal to be had!
That is exactly who tent are targeting.PXLated said:Won't affect me, I'm not on and old grandfathered plan.
That's because that is pretty much flatland and you were along one of the 3 largest east to west corridors on I40. It's the backroads, mountains, and major rock formations that will get you.ChanW said:PXL, I remember you having said that, and I expected the worst. However, on the Interstate coming into NM from Amarillo TX (i40?), and going through Tucumcari, AT&T was good, or at least useable, for the whole way.
Surprised me.
Although any time I went off the interstate for any distance, I lost signal. And it sounds like you're talking about the boonies, not the Interstate.
Since I mostly boondocks when I was using it FT it did not get as much use. It is nice when I am overnighting at a Walmart to pick up nearby wifi or when I am in the backyard and want to pick up the house wifi.DigitalSorceress said:@jkjenn I know this is an old thread.. came here to say I like your setup.. I've gotten myself a WeBoost and was just not wanting to put holes in my camper so I opted for making my own pole out of some PVC pipe.. It stows neatly in my Tow Vehicle and I can set it up when I'm parked.
Got a Verizon JetPack for cellular.. still debating if I want to spend the money for a WiFiRanger.. It does seem like it might be useful. I wish I could test one out first before committing.How is that Nano working out for you all this time later?
