About two weeks ago, I was boon docking and on day 3, I lost power. A fuse at the battery blew. I took out my AGM batteries and replaced them with two 100ah renogy LiFePO4 smart batteries. I installed them the day before yesterday, turned on the bat connect switch on and ....POWER! Last night, I went out to check them....when I turned on battery,...a
all fuses at the battery blew! They are brand new and charged! I still have a separate issue....when batteries are disconnected and plugged into shore power, I have AIR, but no 12V appliances. This lead me to believe the converter.was bad, but when I pulled the converter fuse...the fuse was good, but the converter started. All the other fuses are good....
0 ·
THE FUSE REFERS TO THE CONVERTER POWER FUSE!
I also say, I replaced the AGM WITH LIFEPO4
Jericho, VT
- With AGM batteries you had the same fuse and powering issues
- Replaced AGM with LiFe4PO and the problem(s) persisted
Recent Problem summary- installed charged LI batteries and had correct function in the camper
- opened the battery disconnect switch (disconnected) and left trailer be for a while (I am inferring this)
- later came back and closed the disconnect switch (connected) and "all the fuses at the battery blew"
- also with batteries disconnected and camper connected to 120V (shore power) no 12V is available in the camper, but 120V items are powered and work properly
Questions/clarifications2023 T@B 400 Boondock "Running up a T@B"
Jericho, VT
- I have 120v shore power, but only have 12v shore power when I remove the converter 30 amp power fuse.
Looking to clarify this statement. I am missing something. When the 30A fuse is removed it will disconnect the 12V output of the converter from the 12V circuit, so then only the batteries would provide 12V. If the fuse is in place there should still be 12V present from the batteries even if the converter is not working. If you put your voltmeter on one of the cigar outlets and measure the voltage under these conditions...- Just took a voltmeter to my batts.....13.5 and 13.8 measured.
So can I assume you measured them with them disconnected from the trailer? Is that correct?If yes, then it is interesting that one of the batteries is so much more discharged than the other
If no, then there is current flowing to cause a voltage drop.
Oh...do you have both batteries connected in parallel at the same time or swap them as needed? I have been assuming you have them wired in parallel.
@Horigan is offering a reasonable step to take. I was going to offer something similar once we get some symptoms and conditions established. Maybe there is something up with the breakaway switch, but I hesitate to jump to root cause ideas before getting the data.
Here is a partial wiring diagram I found on this forum from @Bayliss for the 320BDL for reference. I have a 400, so cannot rely on what I see in my camper.
Jericho, VT
- I have two batteries. How do I test continuity with all those wires. Even if I find a problem, if it isn't a fuse or a breaker, how do I fix?
I would recommend waiting on continuity testing. It is harder to do, since it requires disconnecting stuff. You can get an idea of the integrity of the wiring (and if current is flowing) by measuring the voltage drop from one point to another.Let's work on the symptoms and diagnostics first. How and what to fix comes last.
Jericho, VT
"Same configuration as factory" is hard to pin down, since there are variations year to year and even within a model year. We are not all intimately familiar with the variations, so be patient when we asked. If it is one thing I have learned when debugging is to assume nothing.
Back to debug...Having 12V present while on shore power with 30A fuse removed and batteries disconnected is something I am struggling to understand. Without the fuse the converter is not feeding 12V to the camper. Without the batteries connected (switch disconnected) they would not feed 12V to the camper. This is what I am missing...where is the 12V coming from? It is the reason I asked about measuring at one of the cigar outlets in the camper. When you say you "have 12V power" how are you determining this?
Jericho, VT
Both paths you are having trouble with lead to the breakaway. Opening the 30A fuse breaks that path. When you connect the batteries the fuse blows which breaks that path. The problems started when you popped the breakaway. In another thread you mention it looks melted. It is entirely consistent that this is shorted out and needs replacing. It is a single point of failure (SPOF) which fits the symptoms.
If you were to measure the voltage at a cigar plug or one leg of the 30A fuse with the 30A in place you would quite likely read a voltage well below 12V, but not zero.
Jericho, VT
Jericho, VT
Jericho, VT
2015 Little Guy 5-Wide Platform
2015 MB GLK 250 (diesel) Tow Vehicle, "Benzie"
Sequim, WA USA
First off, there has been some very good input from others here, particularly @pthomas745 and @KK1L. To try to build on those questions/suggestions, I went back and reviewed some key information you have provided and will reiterate them in an effort to help you get this particular issue resolved. I have included some questions I have, or inquiries as to clarification that may help:
May 23rd: "I have a T@b 320s 2022. My batteries completely drained after the breakaway switch pin came out. My dealer said my batteries would recover after one to 3 days of charging. Even with dead batteries, shouldn't I still have shore power for lights etc. With the battery disconnected?
Q1: How did the pin come out? Were you able to put it back in? Did the switch appear damaged/melted at that time? Any fuse(s) blown at that time?
MAY 24th: “I only had shore power when I removed the fuse for the converter. I checked the fuses on the batteries and 2 out of 3 were blown....”
Q2: Which fuse "at the converter" did you remove?"
Q3: Specifically, which "2 out of 3 fuses" were blown? (The 30-amp fuses at the two batteries? Or, was one of those the 30-amp fuse at the converter?)
MAY 24th: “Replaced all the fuses ( convertor and batteries). Back in business, all systems ago!”
Q4: When you say you replaced "all" the fuses, are you referring to every fuse in the converter, as well as the 30-amp fuses at the two batteries (one fuse each), or just the two fuses that blew earlier?
MAY 31st: “This past weekend I was boondocking for three days.. the fuse on the group 24 battery (I have a 24 and 31), blew on day 3. Since then, when I turn bat cut off switch on, the fuse blows. I also cannot have shore power unless the converter fuse is out and it is not blown. Could these problems relate to the e brake switch?. I was checking the brakes and I am having a hard time pulling the pin out and the switch looks damaged a little melted...”
Q5: What, if anything, happened between the return to full 12V power on May 24th and your most recent trip around May 31st that may have caused the fuse to blow? Specifically, do you recall anything unusual happening, electrically, during the three days before the fuse on your Group 24 battery blew? What happened or led you to discover that the Group 24 battery fuse blew?
Q6: When you say, "Since then, when I turn bat cut off switch on, the fuse blows," can you clarify whether you first replaced the 30-amp fuse for the Group 24 battery before that happened, or are you referring to a different fuse blowing? If so, which fuse?
Q7: Did this happen more than once? (i.e., did you replace the fuse(s), and then when you again turned the battery disconnect switch "on," the fuse(s) blew again?
JUNE 9th: About two weeks ago, I was boon docking and on day 3, I lost power. A fuse at the battery blew. I took out my AGM batteries and replaced them with two 100ah renogy LiFePO4 smart batteries. I installed them the day before yesterday, turned on the bat connect switch on and ....POWER! Last night, I went out to check them....when I turned on battery,...a all fuses at the battery blew! They are brand new and charged! I still have a separate issue....when batteries are disconnected and plugged into shore power, I have AIR, but no 12V appliances. This lead me to believe the converter was bad, but when I pulled the converter fuse...the fuse was good, but the converter started. All the other fuses are good....
Q8: Is the incident you are describing here (dated JUNE 9th) the same incident you described on May 23rd? I ask, because you initially said the batteries completely drained "after the breakaway pin came out," but you most recently describe that "a fuse at the battery blew" (and thereafter, you switched to two 100Ah Lithium batteries, which resulted in again having power.)
Q9: After you had your 12V power back, am I correct that you turned the battery disconnect switch "off" (thus cutting off power from the batteries to the trailer) and that when you later went to check them and turned the disconnect switch "on," the fuse at each battery blew?
Q10: When you say "all fuses at the battery blew," which fuse(s) specifically are you referring to? I ask, because there should only be one 30-amp fuse for each battery.
Based on the information you have supplied thus far, it does seem that the breakaway switch is damaged and likely shorting out. If not, and assuming there are no other apparent shorts in the wiring, I suppose I would next be looking for a problem with the converter. Maybe the answers to the above questions will lead in another direction.
A FEW MORE GENERAL QUESTIONS FOR YOU: Which Power Center/Converter do you have in your trailer? Have you checked the 40-amp "reversed polarity" fuse in the converter to confirm it is OK? AND, have you confirmed that none of your 120V AC circuit breakers are tripped?
Lastly, have you considered contacting a Mobile RV Repair service to have them come out and try to diagnose the issues you are having with the 12V system?
Sorry for the long post. I hope you get this figured out.
