2022 T@B320 s Boondock - fresh water leak
Filled tank with 18 gallons.  Capacity is supposed to be 19 gallons.   Intentionally overflowed by 1 gallon.  The water did not come out the blue overflow as expected.  It was coming out of the passenger side floor.
Any guidance on how to address would be appreciated.
Thanks
Michael Godshall
Holland PA
2022 T@B 320S Boondock
TV: 2018 F150
    Where did you find the excess water?  The floor?
  • Michael_Godshall
    Michael_Godshall Member Posts: 21
    The water was not inside the camper, it was inside the undercarriage membrane leaking out near the passenger side wheel axle where the screws are not as close together.
    Michael Godshall
    Holland PA
    TV: 2018 F150
    I wonder if the hose leading to the overflow outlet has separated?  Contact nuCamp at help@nucamprv.com.
  • Bayliss
    Bayliss Member Posts: 1,534
    @Michael_Godshall, did you figure out what was causing the water leak?
