2022 T@B320 s Boondock - fresh water leak
Michael_Godshall
Member Posts: 21
Filled tank with 18 gallons. Capacity is supposed to be 19 gallons. Intentionally overflowed by 1 gallon. The water did not come out the blue overflow as expected. It was coming out of the passenger side floor.
Any guidance on how to address would be appreciated.
Thanks
Michael Godshall
Holland PA
2022 T@B 320S Boondock
TV: 2018 F150
Holland PA
TV: 2018 F150
Where did you find the excess water? The floor?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
The water was not inside the camper, it was inside the undercarriage membrane leaking out near the passenger side wheel axle where the screws are not as close together.Michael Godshall
Holland PA
TV: 2018 F1500 -
I wonder if the hose leading to the overflow outlet has separated? Contact nuCamp at help@nucamprv.com.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
@Michael_Godshall, did you figure out what was causing the water leak?2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)0
- 920 Introductions
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
