I just purchased a 2021 Tab 320 Boondock from an individual. The trailer came with a half bottle of Century transfer fluid. I now read that beginning in 2021 you must use a new blue Alde fluid. He told me he topped off the tank before each trip. I have not used the system yet. Do I need to get it to a dealer to have the system flushed out?
2021 T@B 320S Boondock
2018 Jeep Grand Cherokee Summit
0 ·
2020 Tacoma TRD Off-Road
If you're unable to get an estimate on how much Century fluid was added, I would get it flushed out. The fluids are not compatible with each other. The dealer may have some insight on how much is too much.
FWIW I've had bad luck ALDE issues the entire time owning this trailer and they seem to be, at least in part, due to the getting a trailer right before the switchover (it should have come with the blueish-Rhomar fluid but came from the factory with yellow-Century fluid in Dec 2020). My initial corrosion leak started slowly and I was just topping off the fluid not knowing there was an underlying problem -- the trailer was less than a year old and I didn't know what "normal" was.
This document is from the NuCamp website which advises not to mix the fluids and to flush with water prior so I'd be surprised if they recommend not flushing out with water.
2021 Glycol Change Print
Modified on: Fri, 25 Feb, 2022 at 10:58 AM
TRUMA/ALDE GLYCOL SERVICE BULLETIN
SUBJECT: GLYCOL CHANGE
Pleasant Valley Teardrop Trailers/nuCamp has been notified by Truma/Alde that they will be switching to a different brand of glycol. This change is a requirement from Truma/Alde for new units to be eligible for warranty. Due to this requirement, all nuCamp production units manufactured on or after the following dates will have the new glycol. This was a rolling change so if your unit started production on these dates please contact us for confirmation.
TAB 320 S and CS-S: 12-16-2020
TAB 400: 12-22-2020
Cirrus: Week of 12-21-2020
IF YOU ARE UNSURE IF YOUR UNIT HAS THIS NEW GLYCOL, PLEASE CONTACT HELP@NUCAMPRV.COM
NOTE:
The Alde Antifreeze CANNOT be mixed with any other old glycol. If you are changing glycol or winterizing campers the system will need to be flushed with water and blown it out with air to remove all existing glycol. Refill complete Alde system with Alde Antifreeze.
Please see attached document for more specifications on the new glycol.
