Greetings savvy T@B RVers,
I have a 2018 (purchased new) T@B 320S.
I had the dealer install a solar panel plug but have never used panels and I don't know anything about how they work, etc.
I'm told a Renogy 200 Watt 12 Volt Portable Solar Panel with Waterproof 20A Charger Controller would work fine.
I've attached THREE pics that I hope helps illuminate.
THANK YOU sooo much for any help/advice you can give.
You have the option of leaving the charge controller with the panels or placing the charge controller closer to your battery bank. Technically, it would be more efficient if you place the charge controller closer to battery bank - less impact from voltage drop over distance.
It's really set it and forget it except to move panels to capture more sun.
I have the Renogy 200 watt suitcase w/Voyager PWM controller, another HQST 100 Watt Monocrystalline with Voyager PWM controller and now my 190 watt Tab panel w/Victron MPPT controller. They all work great. To make things more flexible and to chase the sun I made up a bunch of different lengths 10 gauge wire w/Anderson connectors. Sometimes I want to park the camper in the shade and put the panels out in the sun.
Renogy 200 Watt 12 Volt Portable Solar Panel with Waterproof 20A Charger Controller, Foldable Adjustable Kickstand, Solar Charger for Power Station RV Camping Off Grid
If you want to keep the panels, say 25-40 feet, from your camper to chase sun you will get marginally better efficiency by keeping the controller closer to your battery bank.
Of course, you could build a system from scratch a lot cheaper, but the Renogy system is very slick and really plug and play.
You could get all tangled up in MPPT vs PWM and wire gauge and anderson vs. SAE vs. solar connectors. My advice would be to keep it simple to start with.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
About the two links, the Amazon link appeared to not be working so I attached the Renogy link.
The cable situation is still a bit confusing.
The cable that comes with the solar panels WILL work/connect to the SAE?
Also, the battery has a 30amp fuse but the solar product kit I'm looking at says it's a 20amp.
That's ok?
Thank you!
I put links to the solar panel kit above in the thread. And photos.
The cable from plug (in photo) is already connected to the T@B battery (30amp fuse).
The solar panel controller says it's 20amp.
I was asking if that's ok.
Thank you!
I'll restrain myself from going on a rant about the stupid SAE connectors (again)...
From this discussion trail and many others I decide to keep it simple and go with the Renogy kit to get started and make sure I bought the right things from the start. It makes a lot more sense when you have the items in hand for sure and good a guide to hand that you are not going to do damage. I did not move the controller near to the camper, just started off easy. Perhaps in the future.
The most complex task below was making the MC4 connections onto the extension.
So hopefully of help to others in the same situation ...
External SAE port (as original factory fit) for our camper
Test polarity
Checked it was fused. On my TAB400 this in inside the external rear storage cubby. (I added the labels).
I just pulled each fuse on by one and saw when the external SAE multimeter dropped to zero, or the victron monitor for the roof solar dropped to zero. The 'Gloss 40A' fuse is for the items inside the camper, that I learnt on this forum all about if you happen to hit the yellow button by accident ....
Bought these cables on Amazon
CERRXIAN 50cm 10AWG SAE to Male & Female Adapter 10AWG Cable with SAE Conector for RV Panel Solar
BougeRV 20 Feet 10AWG Solar Extension Cable with Female and Male Connector with Extra Free Pair of Connectors Solar Panel Adaptor Kit Tool (20FT Red + 20FT Black)
The 20' length reads as about the maximum length for normal use with flexibility to move the panels around.I made the final connections shown above, after checking the exact set up for my needs and keeping positive to positive each set on the way. Lots of youtube videos on make MC4 connections both with and without the crimping tools. (I checked on the web many times to check others but never found an exact description, FYI - my 20' extension in my case is red female to female; black male to male)
SAE plugged in:
Final voltage check, positive to positive, red to red.
Renogy kit
Renogy 200 Watt 12 Volt Portable Solar Panel with Waterproof 20A Charger Controller, Foldable 100W Solar Panel Suitcase with Adjustable Kickstand, Solar Charger for Power Station RV Camping Off Grid
Disconnected the panel from the solar charger by opening the red MC4 connectors as shown in photo below.Read good advice to always store that way,
Connected the battery to the solar charger.
Set for AGM battery type.
Connected the panel to the charger. Sigh of relief as all lights read as OK as per the manual.
The panel set up
Now for our next trip with out hook ups to test for real. Disconnected panel from charger first, and then battery from charger.
Juliet and Andy in Massachusetts
One of the things I dislike about the SAE to SAE extension is that the color coding can be mixed up depending on which end you plug into your solar port. To keep red to red and black to black I crazy glued an MC4 adapter to the end of the SAE to keep the colors consistent.
Thanks a bunch for all of your expertise!
I got mine hooked up and it's working!
Happy trails to you all!!
