Replacement cap for fresh water fill
pak
Member Posts: 134
Lost the cap for my fresh water fill spout. Went to dealer so far no help. Has anyone had this experience or have an idea where I might acquire a replacement. Thank you
You have a non-Nautilus equipped TaB, right?
Past posts suggest the 'factory flip door/cover' fill port is not available for public purchase. Others owners have installed a completely new and different design filler port to solve 'factory' filler damage/lose.
See Replacing the Gravity Water Fill thread.'18 320 S, pitched axle, 3020HE; PNW based
@pak - on our 2017 CSS, we replaced the broken flip style fresh water fill with this one at Amazon:
https://www.amazon.com/JR-Products-Polar-White-Gravity/dp/B000BGM240/ref=sr_1_2?crid=21WKE3UQYFJI&keywords=JR+gravity+water+fill&qid=1692314867&sprefix=jr+gravity+water+fill%2Caps%2C186&sr=8-2
You don't say the year of your trailer, but if you have the fresh water fill that flips open (instead of a cap that screws on), I had to buy an entire new assembly to get the cover. I'm not sure if it's available anymore. It was a terrible design.pak said:Lost the cap for my fresh water fill spout. Went to dealer so far no help. Has anyone had this experience or have an idea where I might acquire a replacement. Thank youI also bought an assembly with the screw on cap, but I wasn't able to get the old assembly out. It was glued in and didn't want to come out even with heat and prying. I was afraid that I'd damage the trailer sidewall if I kept at it.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
I have a 2017 CS-S. Looks like a new style is warranted. Sharon, the link you posted will not open. I suspect the problem is in my settings. Any assistance is appreciated, thank you.0
@pak On my iPad, I touch and hold the link for it to open. I think this was due to a Vanilla update a while back.
Thank you very much.1
Post script: I'm of the age and point where I am tired of fixing things.(end of rant..ha). I decided to see if I just might happen to get a replacement cap through my dealer. After awhile of " nope, that is not it" the parts guy found a part number and ordered the part. Well, the cap came along with the filler valve/spout. It was not a lot of money so I had ordered two. I popped out the cap and installed it on my filler spout. Now I realize sometime in the future I will find it necessary to replace the fill spout. At that time I will use a better designed filler as suggested from fellow t@bbers. Until then I will carry on. Thank you for your suggestions and recommendations.0
@pak ; do you still have the Part Number information? Please share.pak said:
Post script:
. . . parts guy found a part number and ordered the part. . . .
I found the Flapper type water fill cover on ebay.They also have the "screw on cap" filler types. But...both styles include the entire fixture.
Towed by 2014 Touareg TDi2 -
The item listed by 'pthomas' is the exact one I aquired through my dealer.0
