Replacement cap for fresh water fill
Lost the cap for my fresh water fill spout. Went to dealer so far no help. Has anyone had this experience or have an idea where I might acquire a replacement. Thank you
You have a non-Nautilus equipped TaB, right?
Past posts suggest the 'factory flip door/cover' fill port is not available for public purchase. Others owners have installed a completely new and different design filler port to solve 'factory' filler damage/lose.
See Replacing the Gravity Water Fill thread.'18 320 S, pitched axle, 3020HE; PNW based
@pak - on our 2017 CSS, we replaced the broken flip style fresh water fill with this one at Amazon:
https://www.amazon.com/JR-Products-Polar-White-Gravity/dp/B000BGM240/ref=sr_1_2?crid=21WKE3UQYFJI&keywords=JR+gravity+water+fill&qid=1692314867&sprefix=jr+gravity+water+fill%2Caps%2C186&sr=8-2
You don't say the year of your trailer, but if you have the fresh water fill that flips open (instead of a cap that screws on), I had to buy an entire new assembly to get the cover. I'm not sure if it's available anymore. It was a terrible design.pak said:Lost the cap for my fresh water fill spout. Went to dealer so far no help. Has anyone had this experience or have an idea where I might acquire a replacement. Thank youI also bought an assembly with the screw on cap, but I wasn't able to get the old assembly out. It was glued in and didn't want to come out even with heat and prying. I was afraid that I'd damage the trailer sidewall if I kept at it.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
I have a 2017 CS-S. Looks like a new style is warranted. Sharon, the link you posted will not open. I suspect the problem is in my settings. Any assistance is appreciated, thank you.0
@pak On my iPad, I touch and hold the link for it to open. I think this was due to a Vanilla update a while back.
Thank you very much.1
Post script: I'm of the age and point where I am tired of fixing things.(end of rant..ha). I decided to see if I just might happen to get a replacement cap through my dealer. After awhile of " nope, that is not it" the parts guy found a part number and ordered the part. Well, the cap came along with the filler valve/spout. It was not a lot of money so I had ordered two. I popped out the cap and installed it on my filler spout. Now I realize sometime in the future I will find it necessary to replace the fill spout. At that time I will use a better designed filler as suggested from fellow t@bbers. Until then I will carry on. Thank you for your suggestions and recommendations.0
@pak ; do you still have the Part Number information? Please share.pak said:
Post script:
. . . parts guy found a part number and ordered the part. . . .
I found the Flapper type water fill cover on ebay.They also have the "screw on cap" filler types. But...both styles include the entire fixture.
Towed by 2014 Touareg TDi2 -
The item listed by 'pthomas' is the exact one I aquired through my dealer.0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
