Hi, Total newbie to Nucamps. Want to install a Furrion
vision S to the rear of my Tab 320S. Attaching it on the shelf above the
license plate provides easy access to power. I believe that location would also
provide a satisfactory view of the road and campsites while backing up.
Has anyone had experience installing this system? How do you attach the camera to the Tab? Screws, superglue?
Appreciate any advice.
Different ways to power and attach the camera. Mine is powered out of the 12V junction box on the trailer frame near the front. Ran wires exterior /under trailer from TAB rear to junction box. Used a water proof grommet in hole of junction box to run wire in/out. My camera is a license plate mount .
Southern Maryland
No problem seeing what's behind me especially the ground right behind the T@B when backing into a camp site or parking. I wouldn't want it any higher.
2025 KZ Sportsmen 130RD
2023 Ford Maverick XLT
The Finger Lakes of New York
When I eventually get a new camera, I will mount it above the stargazing window of my 400. At the current location, headlights point directly into the camera and make it almost useless at night.
Thank you for your information. Based upon your recommendation, I'll most likely place it on the roof near the fan and access the power from either the fan or the interior light below. Also your suggestion to use VHB tape is also a good one. I'd prefer not to screw into the fiberglass without access to install a backing plate.
https://tab-rv.vanillacommunity.com/discussion/13734/wireless-backup-cameras-monitor-added
2023 T@B 320 S Boondock
