Progressive Industries EMS-HW30C: A delay in providing power is how it works…
MadCityJack
Member Posts: 110
Hi All,
I found out some interesting information today as I was prepping for a camping trip in a couple of weeks. I noticed that when the camper was first plugged and going through the EMS no AC or DC was working for approximately 2 min 15 sec after plugging the camper into a 20 amp home circuit. I measured twice. I thought the converter was a problem. However, when I used the pass through option on the EMS, the converter immediately went on. I contacted tech support at Progressive Industries and they explained that it takes 2 min 16 seconds before power comes through the unit. What a relief and the tech was quite generous in explaining that and more. I learned there is a means of changing it to 15 seconds by opening the EMS unit and attaching a coupler. I was so pleased to know everything was working as it should that I didn’t pay close attention to his “how to” discussion. This is just one of those things that was either not in the manual or that was and I had forgotten about it. Note, that when the power comes through to the converter you may hear a pop if there is anything drawing power.
Happy Camping!
Happy Camping!
2017 T@B 320 Q Max
2018 Toyota Highlander, XLE
Wisconsin
Wisconsin
The older Progressive pole one I had on my motorhome took about three minutes. The newer hardwired I installed in my 2021 T@B is 15 seconds out of the box. It shouldn't be instant as it needs to make sure the power is steady.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York1 -
Our portable Progressive EMS has an audible click as well.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Did they mention any advantage to the longer delay? Does it provide better diagnostics?MadCityJack said:I contacted tech support at Progressive Industries and they explained that it takes 2 min 16 seconds before power comes through the unit. ... I learned there is a means of changing it to 15 seconds by opening the EMS unit and attaching a coupler.
Would be no change in the diagnostics, just a longer sample time before allowing power to pass.AnOldUR said:Did they mention any advantage to the longer delay? Does it provide better diagnostics?2021 T@B 320 S Boondock
2025 Ford Ranger
The Finger Lakes of New York2 -
AnOldUR said:
Did they mention any advantage to the longer delay? Does it provide better diagnostics?MadCityJack said:I contacted tech support at Progressive Industries and they explained that it takes 2 min 16 seconds before power comes through the unit. ... I learned there is a means of changing it to 15 seconds by opening the EMS unit and attaching a coupler.They did not say it made any difference.
2017 T@B 320 Q Max
Wisconsin1
