Maybe this has been posted before...but I've seen the Nautilus getting a bad rap lately!
I had a similar issue with poor suction while trying to winterize....because I emptied my first gallon of anti-freeze, started sucking air, and I lost the prime on my pump. I found that if I open the cold water low-point drain for a few seconds (with a bucket below it), the air would purge quickly and the pump would starting pulling again. For me it worked really well. I also learned to pour 2 gallons of anti-freeze into a bucket before I started....to make sure I didn't run low.
3 ·
2023 T@B 320 S Boondock
2019 Ford F-150 3.5L Ecoboost with Long Bed
Help, oh wise ones!!! (And yes, all lines have been drained and the blow out step completed.)
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
On dry-start-up the pump is moving Air. That air needs to go someplace. With all taps/drains closed the relativity small diaphragm area water pump is working to compress air while it is designed to move water and compress water to 50'ish PSI. Having any cold water tap open allows the air to escape instead of being compressed which means the pump will start pulling/moving water sooner.
How to Prime an RV Water Pump (5 Simple Steps)
place the Alde in by-pass, then pump a small amount of RV antifreeze into the pump.
@pthomas745 - thanks for the recommendation. I have bookmarked this product for future reference if I have trouble going forward.
Appreciate the guidance. This group is just so awesome. I tell all new T@bbers about it when we meet at campgrounds.
Anyway, I can't get the antifreeze to suck up after I blew out my lines. I have tried everything I know: faucets open and closed, pouring it directly in my short hose...we ordered an RV hand pump antifreeze kit that arrives tomorrow (I hope this works but I'm worried).
Do you have any other suggestions?
@Binghi, I have done the elevation trick and also trying to pour into the hose and trying to flow through it. I haven't tried a different washer. Thanks--will give that a try!
I highly recommend to anyone having issues winterizing to get one of these little handpumps. It was so easy to use and we knocked out the task in 5 minutes after spending hours trouble shooting!!
