I am new to winterizing. I keep my tab outdoors in California. antifreeze is not necessary. I want to drain all of the water from the trailer for four month winter non-use. 1) Do I need to drain the water heater tank as well as fresh water and gray water tanks? 2) I do not have an air compressor. After draining everything, can I use an adapter and blow out the remaining water with a hand pump?
Dan
2023 Tab 360 boondock
                0 ·
2020 Tacoma TRD Off-Road
2023 T@B 320 S Boondock
And, if I'm going to use anti-freeze, why bother with blowing out the lines? The anti-freeze pushes any remaining water (after you have drained) out.
2015 Little Guy T@b, TV - 15 Toyota Highlander
"Good friends beware! the only life we knows Flies from us like an arrow from the bow, the Caravan of life is moving by, Quick! to your places in the passing show.”
"Just Enough"
Thanks everyone for your help.
Be well
