4 pin TV adapter to 7 pin Trailer?
I have a Tacoma that I would like to use for an occasional short trip. It only had a 4 pin connector for utility trailers for taillights. I realize I need 7 pin for operation of the trailer brakes and to charge the RV battery while traveling, but is there an adapter so I can connect the two and have the taillights?
I’ve seen adaptors that go the other direction (i.e., 4 pin trailer to 7 pin TV), but I don’t know if the wiring and pins is such that they would work being used in the opposite direction.
2023 T@B 320-S Boondock; 2025 Toyota Tacoma SR
  • Horigan
    Horigan Member Posts: 870
    Search
    Hopkins Towing Solutions 4 Flat to 7 Blade Adapter 47207
    Rich
    2019 T@b 400
    Bellingham WA
  • VictoriaP
    VictoriaP Member Posts: 1,496
    edited November 2023
    As you noted, without the extra wiring of a full 7 pin, you won’t have trailer brakes or trailer battery charging. In some states, it’s illegal to tow without working trailer brakes over a certain weight limit or if the trailer is equipped with them; your vehicle may also require it (owners manual should detail that). Failure to meet that criteria could enable insurance to deny any accident claims. Not worth it in my book, so I had a proper 7 pin installed on my tow vehicle.
    That said, possibly some additional information here, with a whole bunch of links to similar questions that might lead to the right solution for you: https://www.etrailer.com/question-438496.html
    Good luck! And please post if you find something that solves the problem, we’re always interested in options & alternatives around here.
  • SLJ
    SLJ Member Posts: 650
    In most states if your trailer is equipped with brakes, they must be working. At etrailer.com you can get a 7 pin you can mount that has a pigtail that will plug into your four pin and you run an additional line up front to your battery.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • tabiphile
    tabiphile Member Posts: 471
    What year is the Tacoma and is yours a factory or dealer installed towing option? Depending upon the year and options, a seven pin connection is the norm.
  • Mickerly
    Mickerly Member Posts: 486
    Check you local state's rules. For recreational trailers, each state makes their own rules. As the RV owner, you are responsible for following the rules for the state you are operating in. In most of the Midwest, recreational trailers greater that 4000lb require brakes. Most of the 48 contagious states don't require brakes on recreational trailers less then 3000lb. California and the New England states have the most restrictive rules in North America. Although, it is prudent to use trailer brakes if available and trailer brake use reduces wear on the TV. Never confuse legal vs prudent.
    I think what SLJ meant is the rule: if the trailer has brakes, there has to be a system to automatically apply the brakes should the trailer become disconnected from the tow vehicle. You have that if you tow with the battery connected (ON).
    The primary question, I found adapters at the local U-Haul. Used a 4 to 7 when I rented a Silver Shadow. When I bought a 320CS, the tow vehicle got a 7 pin plug. Now I have the other way around, 7 to 4 adapter, for renting U-Haul trailers.
    2018 320CS-S
    "Just Enough"
  • CandJB
    CandJB Member Posts: 17
    @tabiphile- I have a 2004 Tacoma Extended Cab (prior to the 4 door cab). I actually still have the original window sticker from the dealer. Although it has a 2 inch receiver hitch and a 4 pin plug, there isn't an actual tow package listed anywhere. What I have is the way it came from the deal and I don't know if it's factory or dealer installed. It wasn't something I requested to be added.
  • tabiphile
    edited December 2023
    @CandJB, You have a Gen 1 Taco. Hopefully it is not an auto. These did not come with transmission coolers. If you plan to tow with an auto Gen 1Taco you must add a cooler in addition to adding the 7 pin wiring for the brake controller. If you do that, be sure that you never tow in overdrive.
    To read more about this than you will ever want to know; https/www.tacomaworld.com/threads/the-tacoma-towing-bible.4031/
    The Tacoma Towing Bible | Tacoma World
